Question about Samsung LN-T4665F 46 in. LCD Television
On off switch is blinking, but TV is not getting on. what is the reason
    Genius:
  • 1,112 Answers
Hi:
Check for faulty capacitors on the power supply on this model. They will be puffy on their tops indicating overheating or leaky. Most caps tops of the electrolytic type capacitors are flat. Look for ones near the connector coming from the PWR supply connecting to the main board.
Posted on Nov 10, 2010
My baun tv led is flashing red and blue and I've never used it before what is wrong
There are many reasons for these flashes. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Jul 14, 2016 | Televison & Video
TV turned off by itself today, It initially makes a clicking noise, the green power light flashes and goes out after 2-3s hear 2nd click and nothing happens. No red blink lights, nothing.
http://electro-medical.blogspot.com/
Mar 25, 2016 | Panasonic Viera TH-42PZ80U Plasma TV
If my TV just quit working and for no obvious reason , does the indicator light that blinks four times repeatedly mean anything
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 23, 2016 | Panasonic Televison & Video
Sharp TV Aquos LC-32LE165M MODEL no power, the red button will blink only. what's the reason of this?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 31, 2015 | Sharp Televison & Video
How about sony the sony crt tv modelkv-xf21m8j blink twise.give the main reason please
Jan 27, 2015 | Sony Televison & Video
Sony 52w5500 No image, No backlights, 13 and 14 blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 27, 2014 | Sony KDL-52W5500 52 inch Multi-System Full...
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Tv shuts off after screen goes red
Good Day sir, the reason why your tv act that way is the switching power supply. The power supply regulator, cannot supply the current needed by your TV. these can be caused by several factors. a faulty switching regulator, low power, or filter capacitor leaking, check the voltage across the VCC after the regulator, if possible the switching transistor. and the ic that controls the pulse they are usually near each other. for safety reasons, better consult your service personnel. hope this helps. if you need more assistance, do let me know. thanks
Jul 28, 2009 | Televison & Video
Sony KV36FS100 - Has sound but no picture and stand by light blinks when TV is off
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 24, 2017 | Sony KV-36FS100 36" TV
Samsung LN-T4665F 46 in. LCD Television Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
