Question about Minolta Office Equipment & Supplies
How do i use the scanner in minolta dialta Dil6ll copier machine?and is there a manula for this.can you send me copy
  • Minolta Master
  • 6,161 Answers
Yes if go to KonicaMinolta web site. You should be able to down load the manual
Posted on Jan 01, 2015
2 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: My minolta dialta copier has
This code deals with the AIDC or Automatic Image Density Control failure. Most always this code is caused by toner collecting on top of the sensor. If you happen to know how to remove the Imaging Unit and then the Drum from the Imaging Unit then you could clean the sensor yourself. If not then I would recommend you call a service technician to correct the problem.
Basically what is happening is there is a thin mylar seal called the anti-spill mylar which is suppose to keep the toner off of the sensor. But these start to fail over time and allow toner to drop down onto the sensor which results in false readings and the C0F24 code. The mylar must either be replaced or what I do as a field fix is to reform the mylar back to it's like new shape so it seals. Then clean the sensor area of toner then re-install the drum and imaging unit back into the machine.
Good Luck and Thank You for using Fixya.
Posted on Aug 04, 2010
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Only copy a half of the paper
Check the exposure lamp light.Open the document feder cover,verify the lamp light(press the cover contact manually),if the lamp is light to half side,remove the glass,pull the scanner assembly in the left position use the alufolio and transparent scotch for repair the damaged parts.Verify the lamp ground continuity use Ohm meter.
Mar 06, 2012 | Konica Minolta DiALTA Di200 Copier
My copier makes dirty copies.. how can i clean the machine, it is not on the glass
Send you get fat service documentation Minolta Di200.
Shall is thanked if tell to FiXya about me.Good luck!
http://files.mail.ru/MMS9BH
Sep 28, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta dialta di 181 error no c1440 machine not working
Scanner exposure lamp out. Try opening thr front door to reset, if not new lamp
May 07, 2009 | Konica Minolta DiALTA Di183F Copier
How do you change the toner in a Minolta Dialta copy machine?
Check the back of the machine see if the sticker is still on it. Model number should be there. As for toner carefully remove the toner bottle turn the machine off wait ten seconds turn the machine on do not put the bottle of toner in until the waning comes on to tell you to add toner. The word "up" on the toner bottle should be visible onthe tup when you install it, so should the hole. Theres a small nub that will lock int place when installing it.
Apr 01, 2009 | Minolta DiALTA Di183 Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
