Question about Federal Industries RSSM478SC Commercial Refrigerator
It's not cooling properely. It starts to cool for a minute and then turns off.
Why can i not cook for 20 minutes with oyster microwave it cooks about 7 minutes an shuts off then about 5 minutes later it starts up again.
The unit could be overheating and shutting down, cooling off, and restarting. Check ventilation holes on back for dust accumulation and blockage. Check that cooling fan is turning properly.
Nov 26, 2017 | Microwave Ovens
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
Car overheated Iin November of 2010. Turned it off, cooled it down, added coolant - no further problems. Today, May of 2011, red warning light came on 10 minutes into drive. 50's outside temp. ...
Sounds like a bad water pump or radiator. Make sure the radiator fins arent clogged or inside of radiator, water pump not circulating the coolant properly will also cause overheating, old coolant will not properly dissipate heat efficiently and may need flushed. Also make sure the coolant has a 50% mix of water as the water does most of the cooling not the antifreeze. Hope this gives you some good places to start.
May 13, 2011 | BMW 325 Cars & Trucks
2000chev1500havetoflushheatercoreevery2monstogetheat
I recommend this procedure, starting with a cold engine: Remove the radiator cap, remove the thermostat, re-install the thermostat housing, leave the radiator cap off, start engine and idle for not less than fifteen minutes, then turn engine off. Allow engine and radiator to cool completely, then open the petcock at the bottom of the radiator, and drain completely (there will still be some coolant/water in the system).
Remove the thermostat housing again, then remove the old water pump and install a new water pump, replace the thermostat with a new one rated at 195 degrees, and be sure to install it in the proper direction. Fill radiator with water only (you don't want to waste money on antifreeze until you are sure you have heat), leave radiator cap off, start engine and let it come to operating temperature, not less than fifteen minutes. Turn engine off, and let cool compltely. Fill radiator with water only, install radiator cap, and restart vehicle. Let come to operating temperature again, not less than fifteen minutes, turn off. Let cool completely, drain radiator again if your truck got proper heat in cabin, then refill with the proper mixture of water/antifreeze. This sounds like a lot of repetition, but this will flush your entire system, boost your water pressure, and properly regulate your engine temperature. If the problem repeats in your two month window, have the radiator professionally serviced and the heater core will probably have to be replaced.
Always use the proper type and amount of anitfreeze!
Jan 28, 2010 | 2000 Chevrolet Silverado
A/c turns on for 10 minutes
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Federal Industries RSSM478SC Commercial Refrigerator Logo
32 people viewed this question
Top Federal Industries Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Federal Industries Refrigerator Expert? Answer questions, earn points and help others
