Question about Acer Computers & Internet
  • skybe74 Jun 20, 2008
  • 214 Answers
It seems your PC is having some kind of hardware problem.
It can be a loose connection or so. If you have little bit of experience in opening the PC, try yourself. Also check listen to the type of beep it produces.
If there is 2 beeps its RAM problem or if it beeps continuasly, its power supply problem.
If you doubt RAM, have a new one and check.
It it does'nt help, take it to the nearest service tech. It does'nt cost that much
good luck
Posted on Jun 17, 2008
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
Hp cq60 keybord not working it beeping
Myself Srikanth, I am tech support eng at HP. At this point, I recommend you to contact the HP service center if it is under Accidental damage warranty which covers liquid spills. Or if you are computer savy, you can remove the keyboard laptop keyboard connection and check with the external keyboard. This issue will occer when any liquid spilled on keyboard and some of the keys were attached to the circuit. If the external keyboard worked fine then just send me the keyboard part number i will help you to purchase the new keyboard.
Thank you
Oct 09, 2012 | HP Compaq Presario CQ60-249US Notebook
How to widen my screen
    • 1 Use the zoom in and out shortcut with your mouse. Many programs such as Internet Explorer, Firefox and Microsoft Word allow users to zoom in and out quickly using their mouse and keyboard. Hold down the "Control" ("Ctrl") key, and then move the mouse wheel forward to zoom in or backward to zoom out until the text fits your screen to your liking.
    • 2 Use the zoom command from your program's menus. If you don't have a mouse with a wheel or the mouse zoom shortcut does not work, try locating a "zoom" command in the "View" menu of your program. Many programs have an option to zoom in and out under the "View" menu, which will make text larger or smaller. You may have to select "Zoom in" or "Zoom out" several times before the text is the right size.
    • 3 Change your screen resolution. Altering your screen resolution can change the size of windows and text on your screen. Right click the desktop, select "Properties" (Windows XP) or "Personalize" (Windows Vista and 7), click the "Settings" tab (XP), or the "Display Settings" link (Vista) or click "Display" and then "Adjust Screen Resolution" (7). Adjust the resolution slider up or down, click "Apply" and then click "OK."
Oct 23, 2011 | Dell Dimension 2400 PC Desktop
My acer aspire one notebook laptop when I push the power button comes on and shows the start up screen and then the screen instantly goes to this black screen with a little white line blinking in the top...
Perhaps you've built a computer and are turning it on for the first time, or you've owned this computer for awhile. Either way, you may encounter an issue where the monitor shows a black screen and the computer is beeping. There are several causes and solutions for this problem.
1.Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
2.Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
3.Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
4.Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
I hope you find it very helpful.
Aug 25, 2011 | Acer Aspire One PC Notebook
Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
Jan 08, 2011 | Intel Motherboard
When i turn the game on, it goes to the loading screen, loads my profile, but when the message box pops up saying "syncronizing nba today. please wait..." it freezes and emits a beeping noise....
go to your Wii settings and turn off the internet so there's no way to get to NBA Today. Then the sychronize part is excluded when you start loading to play.Sorry, but you can't play online though
Nov 21, 2010 | Nintendo NBA 2K10 for Wii
I have a Dell Dimension 3100 which has recently moved house, and will not longer start up. The PC will switch on through the mains, but there is a series of 6 - 8 short beeping sounds, and the monitor...
I think you need to open the PC up and reseat the RAM modules, and the HDD cable and the CD/DVD cable too, make sure the power supply cable is secure too.
Also make sure you have the Video cable connected correctly too. Also the Keyboard & Mouse check them, they go color to color, also temporarily remove any USB connected devices. Connect them up after you have a desktop.
Those beeps usually indicate No Ram, or No video or both.
Sep 07, 2010 | Dell Dimension 3100 PC Desktop
Wireless key board & mouse
  • Decide where the keyboard will be placed, whether it is on your desk or a table. Spend a little time experimenting with positions and placement to make sure your wrists and arms will be comfortable. You should consider ergonomics before you set up the keyboard to avoid repetitive motion injuries later on.
  • Step 2 Install the batteries (usually three AA) in your wireless keyboard. Replace the cover securely so the batteries are connected properly. Turn the keyboard on.
  • Step 3 Get out the wireless receiver that came with your keyboard. Position it close to your computer, but not closer than about 8 inches, as the computer itself can cause interference with the wireless signal. You will also want to set the receiver away from other interference-causing devices, such as radios, TVs and telephones.
  • Step 4 Ensure that your wireless receiver is no more than about 6 feet away from where you plan to set your keyboard.
  • Step 5 Insert the CD containing the accompanying software into your computer. A dialog box should appear on your screen. If the install instructions don't pop up right away, manually access the CD by double-clicking its icon or selecting it from the Start menu.
  • Step 6 Plug the wireless receiver into a free USB portmag-glass_10x10.gif on your computer. If you don't have any ports remaining on your computer, you can use an external USB hub instead.
  • Jul 07, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    Continuous beeping sound
    you can see out put in screen if no you must chek ram's
    else you should remove your keyboard and mouse in test ather
    Dec 16, 2007 | Packard Bell iMedia SL 9553 (P660401806)...
    Computers & Internet Logo
    61 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
