Question about Sharp Televison & Video
No sound from my sharp aqous 37d4u. The sound was on, turned the tv off, turned it back on later and nothing. Unplugged it, reset it. still no sound.
  • 927 Answers
Good Day;
You stated you have no sound after turning the TV off, and had reset it & still no sound. Well you did the right thing, but are you using a cable or sat. box? If so did you reset those or make those 'boxes' volume's were not turned down.
After resetting the entire system and checking for volume levels it sounds like the LCD may have a defective A/V (audio/ video) board that is really easy to replace. 90% of your audio circuit is on that board.
Good Luck; Big I.
Posted on Jun 17, 2008
Sharp AQOUS 42 tv will not turn off and displays the Sharp logo and the screen goes black, like it is transitioning, but never transitions to another screen. How do I fix this and what is the issue?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 05, 2016 | Sharp Aquos Televison & Video
Sharp Aquos 37" LCD TV sound quit
You could open up the TV and look for signs of burnt components then try to replace the components or try to find a replacement for the entire affected board on ebay or something. If you can find out what the problem is maybe the service person will lower there price. $600 does seem very steap, it should be something closer to $60 an hour with maybe the first $60 as an estimate.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Half a screen on my sharp aqous
There's a circuit board under a metal cover that needs to be replaced. This board conrtols the picture.
Aug 28, 2012 | Sharp 60" Aquos LED Smart TV - LC60LE640U
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
My sharpe aqous runs for so long then a message appears saying the tv will automatically switch of in 5 mins, this appears every minute until the 5 mins are up. I have checked and the sleeper timer is set...
Tries unplug,replug tv an hour later.Let the tv reset itself.Than goto tv Menu go to PICTURE,go down to reset.This will reset everything on the tv Tuner board back to factory setting.This should solved ur problems.Not,than the tv Tuner board have intermitten isuse problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 13, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LC-37D4U TV sharp aquos
Sorry, the only reason I have tv and video listed on my expertice is becouse of remote controls, people post them sometimes under wrong things so I add the whole thing to get the most problems.
ask another expert, use the find experts link on the front page, slinteriors should be able to help ya
Sep 17, 2008 | Sharp LC-37D4U 37 in. LCD Television
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Sound goes out from getting hot
I would call his tail and tell him the problem has come back and he needs to too. He needs to check and see if the proper voltage is at the pins of that IC.
Oct 21, 2007 | Sharp LC-37D4U 37 in. LCD Television
Sound only comes on after about an hour
I had the exact same problem. It was very frustrating to say the least. As it turned out the AV board went out and it cost $600 at total of $800 including labor, which makes this very expensive to replace. I actually had to think about junking the unit before it was even two years old.
Oct 02, 2007 | Sharp LC-37D4U 37 in. LCD Television
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
