The driver I installed is giving command error message on the printer display. I gues Am using wrong driver. The printer is zebra p420c. I need another current driver. Thanks
    Genius:
  • 1,112 Answers
Hello:
First go to the printers makers website and click on support, here you will be able to download the right drivers and manuals, even some of software that came with the printer. U did not mention which kind of printer to have.
Posted on Nov 10, 2010
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Printing labels from SAP ECC 6.0 using smarforms, label prints however the printer commands themselves are showing on the label, not just the information the print commands are to control. Is there...
Hi there
Does this printer connected with your computer? If yes, there is a problem on printer driver. You need to add new printer with same name and if this successfully installed, you can delete the old printer icon.
When there is errors message or wrong command of printing, the usual problem is corrupted driver.
Another way to correct this is to uninstall and reinstall the printer driver if the first solution does not work.
If still not working, try this download and install the print diagnostics software. It will helps you to find and fix errors in the windows registry. Here is the link http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Click on the blue text PRINT DIAGNOSTIC UTILITY and it will download automatically. Unzip it to install to your computer.
I hope these solutions solve your problem. Regards.
Feb 09, 2011 | Zebra RW 420 Thermal Printer
Controlador de impresora zebra modelo p420c
Saludos. Conseguiste el driver para windows 7?
Jan 07, 2011 | Zebra Eltron P420C Printer
Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Jan 21, 2010 | Zebra Eltron P420C Printer
The Zebra P420C printer was working fine then it would not print any cards. The unit was cleaned and a print head replaced the unit will still not print any solutions. SN611182 (newer style)
try going into the hardware install/removal wizard or into device manager to remove and reinstall the driver for the unit this may help.
Oct 02, 2009 | Zebra Eltron P420C Printer
ZEBRA Z140 PRINTER sw error ADDR:0080F298
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Mar 13, 2009 | Zebra Printer 140-751-00000
How do I reset the card-print counter on an Eltron P420C
u select the properties and search for tabs like card count,details etc and reset thecount to 0.im not sure about this answer this may work or may not be.
Aug 26, 2008 | Zebra Eltron P420C Printer
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
