Question about RTX DUALphone 3088 for Skype
Model RTX 3088. Sound of incoming calls are not heared in handset anymore, neither landline nor Skype. I had checked all controls and settings. No positive effect. Outgoing calls are ok.
  • Bison47 Nov 10, 2010
    To my much regret both settingf Ring tone and Call divert are ok and switched correctly. But incoming calls are not heared at all. I have two handsets in my household . One is working properly but the second one causing these problems. Waiting your next advise.
  • Bison47 Nov 11, 2010
    Will try repair in a shop
  • 2,069 Answers
Do you mean the ringing tone? our the Earpiece of your RTX 3088. but since you say landline too, probably you mean ringer. so when you call out, you are able to hear them and they hear you right? I will assume that the landline is inserted in the RTX 3088 base and you are using it as a 2in1. you could have muted your set. Adjust the volume via Settings ==>Tones ==> Ring tones.
Posted on Nov 10, 2010
  • 1 more comment
  • Muzahura Frank Nov 10, 2010
    another reason could be if you have enable Call divert, which means that all incoming Skype calls are forwarded. Disable call forwarding via Settings ==> Call divert ==> Call forward.
  • Muzahura Frank Nov 11, 2010
    then that means the the ringer (hardware) is faulty or has gone loose. it can happen and solution would be opening up handset and checking for ringer looseness or replace it. this may require some tools and slight skill..otherwise, take it to the nearest phone service point . it is something very easy to fix.
    regards
  • jimirin Dec 21, 2010
    I think I have the same problem as Bison47. (I don't have a landline phoneline connected to the RTX 3088, only the network cable for Skype). With incoming calls from both Skype and landlines to my Skype In number, the handsets ring normal and show who is ringing on the display normal. However, when you answer the call there is no sound and the person on the other end cannot hear me either. If I use my PC to answer these calls, SkypeIn works fine, but answering calls with the RTX 3088 doesnot work.
    For your info: outgoing calls to landlines work fine using the RTX 3088.
    Hope someone knows what to do.
The person i am calling cannot hear me dualphone 3088
I downgraded the firmware to a version back and then upgraded back to latest and it worked for me.
Jun 18, 2012 | RTX DUALphone 3088 for Skype
Hi, I buy two phones 3088, and in both, time to
There are a few things that cause what you describe:1. The landline is having problems and your phone is trying to alert you so that you know not to use it2. The internet connection is having problems,3. You have voice mail or other notifications that wait your attention.To avoid any issues you should update the firmware on both devices.
Have a nice day!Vlad
Dec 24, 2011 | RTX DUALphone 3088 for Skype
My two RTX Dual 3088 handsets do not ring when receiving calls (display light comes on and I can answer if I happen to look at my handset right when someone is calling me) and make no beep when I press...
I have exectly the same problem.After surfing the internet i found out that many people experience such bug and nobody has solved the problem by themselves so far.So if somebody knows what to do, please tell us.
Jul 09, 2011 | RTX DUALphone 3088
I can't hear the phone when I receive a call. Have
I had the same problem with the latest firmware (Version 250). It was working perfectly earlier but this problem arose suddendly. I fixed it after many days by installing an older firmware (Version 245 in my case) and then installing the latest firmware again (Version 250).
You can install the firmware by going to:
Menu > Settings > Advanced > Firmware Update > All Firmware vers. > (select firmware version) > Install
Please make sure that you don't loose power and internet to your base station during the update. Also, your handset should be fully charged.
Hope this will help everyone who has the problem.
Apr 05, 2011 | RTX DUALphone 3088 for Skype
The microphone of my dualphone 3088 is working properly with the land line but not at all with skype.
You have to change te properties of microfone and speaker in the Skype to the phone.
Go to tools->options, enter audio settings and define your phone for mic and speaker.
Nov 13, 2010 | RTX DUALphone 3088
I have no audio on my rtx 3088. i can log into it, retrieve my contacts, call it, but there is no audio in or out. i use a wireless-n netgear router and live in japan. i have tried making a skype test...
your ring type is set to be in silence, to make it ring go to menu --> settings -->. basic -->ring type --> and select a ring type, the above mentioned steps may not be exact
Apr 17, 2010 | RTX DUALphone 3088
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
I cannot sign in to skype with my dualphone 3088
I have a skype dualphone 3088 and I cannot sign in.
Nov 17, 2009 | RTX DUALphone 3088
The phone can not sign in
I had excatly the same problems and therefore I called the Dualphone hotline. A very helpful person send me this code, which I used and after 2 days with many frustrations this solved all problems within 30 minutes:
"Dear Sir, madam,
Thank you for contacting dual phone Support.
"Press menu followed by 1 – 3 – 9 – 7 – 5. You will prompt to one pageFWU configuration and select Beta firmware. Install the 0247 beta firmware."
Best regards,
Dualphone support"
Hope it can someone
Stein
Aug 03, 2008 | RTX DUALphone 3088
RTX DUALphone 3088 for Skype Logo
427 people viewed this question
Top RTX Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a RTX Lands Phone Expert? Answer questions, earn points and help others
