Question about Kodak EasyShare C310 Digital Camera
I keep getting a formatting error when I try to delete everything off of my memory card
    Genius:
  • 1,177 Answers
You could try formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible. If it does format, all the pics will be deleted in the process.
Posted on Nov 10, 2010
Memory card error
Try using a different SD memory card. You can also try formatting your memory card, BUT that will delete everything stored on your memory card.
Oct 28, 2012 | Pentax K10D Digital Camera
I just put in a new memory card into a Canon A590 that I bought on eBay. It powers up and everything else looks fine but I get the memory card error..I did unlock the memory card itself so that is not the...
1. Try to format the card in the camera. It should give an error when faulty.
2. Put the card in a pc with cardreader and download this testprogram.
3. Run this program to test the memorycard.
4. Delete afterwards the test contents or re-format it.
Aug 29, 2011 | Canon PowerShot A590 IS Digital Camera
When you get memory card error on every card you put in your camera, what needs fixing? The camera or the card? All 4 cards gave the same error. I already got all the pictures off of them and deleted...
You said it in the last seven words "deleted the pictures off the memory cards" Once the pictures have been downloaded to the computer Hard Drive you need to Format the memory card. Formatting a memory card is done in the camera it is to be used which brings it back to a clean surface and compatibility. Your manual said that "normally" formatting isn't necessary which is a pile the bull left behind. I could go into detail as to why format but I'm trying to keep this short/
Here is a diagram to show you where the "format" menus is and what to do with it.
Diagram
Cheers
Jan 18, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
Memory card error card says locked
Hi!
SD cards (or MicroSD, using an adapter) are locked using a mechanical switch on their left side.
Simply, take the SD card (or the SD adapter) and change the switch position.
Usually the UP position is the Unlocked position...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
B
est regards,
Pelu.
Jan 04, 2011 | Canon PowerShot SD1100 IS Digital Camera
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Format error and flashing C:13:01
Format error is a problem with the memory card.
Try using a card reader and a computer to recover the files inside the card, saving them on the computer.
When you have finished try formatting the memory stick or replace it with a new one.
If you still get the error with a newly formatted memory stick, then that is a faulty mainboard inside the camera, but this is not common.
Usually you fix C:13:01 just formatting or replacing the memory card.
Feb 24, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory full error
try re-formatting the card before putting items back on see if that makes a difference..
Oct 10, 2008 | SanDisk 2GB microSD Memory Card
When i try to ytyake a picture an error message appears memory card error
Is that exact what it says? I need more information. What kind of camera is it? I'll try to help with the little information I have:
I think your memory card is full and needs to be formatted. Select 'Menu' and look for the 'Format' option and select it. Before you select 'Yes' make sure you save any pictures that you might want to keep onto your computer. Because once the memory card is formatted you won't be able retrieve the pictures. It should ask you before formatting your memory card. While it's formatting make sure to keep the camera steady (if it's an older camera the slightest bump could disrupt the formatting process). This should take no more that a minute or two. When it's complete your memory card will be completely wiped clean. You'll now be able to take pictures. If the message appears again repeat the same process.
Note: When you 'Delete' a picture it doesn't completely leave your memory card. It will continue to take up space until you format your card.
I suggest formatting your memory card often (or you might miss out on a perfect photo opportunity and have to delete pictures you haven't put on your computer yet).
I hope this helped,
Owen
Sep 22, 2008 | Cameras
Crappy nokia n70
To format a memory card on the N70:
Menu/Tools/Memory card,open it, Options, scroll down to Format memory card.
May 23, 2008 | Nokia N70 Cellular Phone
Kodak EasyShare C310 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
