Question about Vizio VW26L 26 in. LCD TV
When i turned the tv on, it flickered right away and i can hear a ticking sound. I has been 2 years that we've had the tv but this is the first time we had that problem. No other electronic devices near the tv but a regular speaker and the surge protector.
    Genius:
  • 1,112 Answers
Hi
This is due to a fault in the power supply,It involves some capacitors on the power supply that are leaky. if you take the back off and examine the power supplys capacitors, the bad ones are buldging at their tops. NOTE: Most caps are flat on their tops. The ones that usually go bad are the values 2200uf rated at 35v, and 680uf rated at 10Volts there may be at least 4 that needs replacing and they are all round each other usually near the connector that connects the PS to the Main board.
Posted on Nov 10, 2010
Ticking noise on engine
Sounds like the trimming chain. What kinda of car and year?
Apr 23, 2013 | Vehicle Parts & Accessories
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months...
no solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Sep 07, 2010 | Samsung HLP5085W 50" Rear Projection...
Sharp 2DR-S100S Ticking sound, will not turn on
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Feb 22, 2009 | Sharp 25R-S100 25" TV
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Vizio VW26L 26 in. LCD TV Logo
103 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
