Question about Dell 3110cn Laser Printer
EN EL VISOR DE LA IMPRESORA DELL 3110 cn, AL INTENTAR IMPRIMIR UN DOCUMENTO DE POWER POINT, APARECE EL SIGUIENTE MENSAJE "SOLICITUD PDL. VIOLACIÃ?N DE DATOS PULSE ACEPTAR. GRACIAS
3 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: cuando instale a 5to usuario
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
Joed911
  • 4338 Answers
SOURCE: el problema que tengo es
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Posted on Nov 30, 2010
Hola me sale cambiar fusor en una impresora oki b6200 como quito ese error sin cambiar el fusor
Acci?n:
Encendido y espere hasta que la lista para imprimir el mensaje aparece en el panel del operador.
Pulse el bot?n "Seleccionar y el bot?n de flecha hacia abajo al mismo tiempo"
El men? siguiente aparece "Reiniciar contador del fusor U4"
Pulse el bot?n de flecha derecha
Panel del operador mostrar? "Fuser U4 Utilice el SEL para Reset"
Pulse el bot?n SELECT
Panel del operador leer? "Clearing"
Pulse la tecla Men? para volver al "Modo Listo para Imprimir"
Aug 31, 2012 | OKI B6200 Laser Printer
A quien corresponda, tenemos el equipo HP Photosmart C5180 All-in-One, que presenta el siguiente problema: cuando se enciende, no termina nunca de iniciar el menu en el Display, se reinicia continuamente,...
Hola este problema, también lo estoy sufriendo... encontre la solución aquí, http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C5180-Power-Up-Power-Down-Problem-Loops-on-off-on-off/td-p/132152 son los foros oficiales del servicio HP, al parecer no se hacen responsables, es un fallo que ocurre a bastantes usuarios. Según comentan otros usuarios se ha de realizar la sustitución de unos condensadores, leer las 4 páginas del post. He dejado la impresora unas 3 horas aproximadamente en el bucle dichoso y finalmente ha arrancado. Igualmente en ese mismo post viene como hacer un reset a la memoria de la impresora.
Un saludo y espero haber servido de ayuda.
Mar 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nov 30, 2010 | Dell 3100cn Laser Printer
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
Imprime las facturas pero no los albaranes
Esto parece ser un problema de software mas que de la impresora. Si el documento a imprimir contiene graficos (Codigo de barras u otros), es posible que no tenga la configuracion correcta. Recomiendo proporcionar mas informacion al respecto (Que programa usa, tiene el manual de la impresora? Trabaja en Windows o msdos, etc)
Nov 23, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ┬┐Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
Como iniciar el escaneo de un documento desde el ordenador ?
Usando el software de la impresora
1 Encienda el ordenador y la impresora, y asegúrese de que estén conectados.
2 Cargue el documento original. Para obtener ayuda, consulte "Cargue un documento original en el alimentador automático de documentos" en la
la página 24 o "Colocación de su documento original sobre el cristal del escáner" en la página 25.
3 Haga clic en Inicio → Programas o Todos los programas → Impresoras Impresoras Dell → Dell Photo AIO
→ 964 Dell All-In-One Center.
La Dell All-In-One Center abre.
4 Haga clic en Ver presentación preliminar para ver la imagen escaneada.
NOTA: Si el tamaño de la exploración (que se encuentra en la parte inferior derecha de la ventana de vista previa) aparece en rojo, lo hace
que no cuentan con los recursos del sistema disponibles para realizar la exploración en la resolución o el tamaño que tienen
seleccionado. Para corregir este problema, reduzca la resolución o el tamaño de su área de escaneo.
5 Ajuste las líneas punteadas para encajar alrededor de la parte de la imagen que desea escanear.
6 En la Enviar imagen escaneada a: menú desplegable, seleccione su destino de escaneo.
7 Para personalizar aún más su trabajo de exploración, haga clic en Ver más opciones de escaneo.
8 Cuando haya terminado de personalizar la imagen, haga clic en Escanear.
Oct 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Dell 3110cn Laser Printer Logo
20 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
