Question about Whirlpool Refrigerators
Whirlpool Refrigerator model WBM35LS The fridge beeps all the time even while the door is closed. There would be about a second inbetween each beep.
  • 4 Answers
I know this is an old thread, but in case others like myself are still looking.
This issue is to do with the Potency Module, which is the main computer for the fridge. The 2uF 450V capacitor has a tendency to fail. This acts as a divider circuit and as it fails it means the board can not supply enough power, so when the Compressor is running and you open the door, the light tips it over the edge and it causes the relays on the board to drop in and out. Literally making the fridge turn on and off. The potency module is fairly easy to get at. It is at the rear, bottom left, behind a metal plate. 3 hex head screws removed get it out.
This model has a magnetic door switch, so there is no mechanical door switch to go bad. If the door switch is the issue, a $250 interface board needs to be replaced. That is not the issue though. The Potency Module is the issue. It varies in price from $200 to $450 depending where you source it from. Not worth it if you need a tradie to replace it, but if you can repair or replace it yourself it would be possibly worth while.
Posted on Jun 04, 2017
    Genius:
  • 1,622 Answers
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
I hope this will help in solving the problem, Take care in handling the refrigerator...
Posted on Nov 10, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
My fridge does the open door beep and motor on/off just by opening the door. Ive searched through here and suggestion is to clean the door switch, but I cant find the door switch on freezer or fridge...
Depending on which two numbers after the ET1FHTXM may make a difference. For example ET1FHTXM00 the only thing that may cause a beep or cut the refrigerator (that I know of) on or off would be=> Circuit Board or Timer 2213473 This is a ADC adaptive defrost control and when they go bad strange things happen.Click Here=>
Whirlpool ET1FHTXMQ01 parts manual.pdf
You can also find a Tech Sheet wiring diagram=> Here
Thanks, Sea Breeze
Jan 26, 2011 | Whirlpool ET1FHTXM Top Freezer...
The alarm beeper keeps beeping even though the doors are closed. The fridge has been sitting for about a year.
hi,
you can check a limit switch at its door. it is located usually at the door area inside.
maybe it is not working already or get stuck that is why it doesn't sense that the door is closed.
most of the time it is getting stuck and you can fix it by just pulling it out or other ways to do it.
hope that solves your problem.
Don't forget to rate me. Thanks...
Regards,
John
Jan 10, 2011 | Samsung RB215LASH
My whirlpool refrigerator beeps continuosly when i open the door, the light flashers also & the motor sounds like it stops & starts also. What is the problem?
Hello All.
I would like to add my findings.
My fridge WBM46LS of 11 years started behaving exactly as the OP described. I tried all the suggestions regarding holding buttons, power off etc to no avail.
I even found an online manual here
https://www.yumpu.com/en/document/view/18647891/whirlpool-uk-refrigerator-models-wbm35lw-wbm35ls-/5
But that did not address the problem at all.
So I went back to someones suggestion about the Potency Module.
I pulled the fridge out and unscrewed the cover at the bottom left to get access to the Potency module.(Red plastic box)
Without even pulling it open I could smell the burnt electronics.
I opened up the case and found a scorch mark next to the big capacitor on the circuit board.
So far, so good.
Given that a new fridge of the same size/style is about $1300 I pursued the spare part.
I then tracked down a supplier in Melbourne with a new board/module for $148.50. P# WPP326020913
Plugged in the new board in and fired up the fridge and its working just like new.
So I am happy now that a perfectly good fridge is up and working again.
Dec 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
I have a Whirlpool fridge WBM46LW top freezer that the alarms beeps, light flashes and motor cuts in & out when door opens or sometimes after a few seconds with door open.
Hello All.
My fridge of 11 years started behaving exactly as the OP described. I tried all the suggestions regarding holding buttons, power off etc to no avail.
So far, so good.
Jul 28, 2010 | Whirlpool Refrigerators
When fridge/freezer door is opened the fridge starts beeping and the light constantly turns on and off until the door is closed
WHEN i OPEN MY WHIRLPOOL FRIDGE THE LIGHT FLASHES ON AND OFF AND THE COMPRESSOR APPEARS TO CUT IN AND OUT AND THE FRIDGE BEEPS UNTIL DOOR IS CLOSED. cAN ANYONE HELP?
May 23, 2010 | Whirlpool Refrigerators
My Whirlpool WBM35LW refrigerator now beeps intermitantly even when the door is closed. This is very annoying.
Throw it out and don't buy Whirlpool again. I had the same fridge and it was doing the same thing and would of cost heaps to fix it.
Feb 02, 2010 | Refrigerators
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
348 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
