Question about Coleman Propane Grill Stove 9921-700
No gas going to grill.
Coleman stove/grill worked twice just fine and now won't turn on as if there's no gas going to it. Using same gas cannister and a new one, neither works. Connections seem the same as when they worked. Any Help?
  • 1 more comment
  • Anonymous Aug 19, 2008
    grill not igniting. I have used three different gas cylinders to no avail. I took stove apart and looked for a problem and stove still did not ignite. It appears that no gas is reaching the burners. What do I do next?
  • Warren Criswell Dec 30, 2012
    I have the same problem. Nobody seems to have a solution.
  • Anonymous Mar 29, 2014
    grill has 2 burner, one is working fine but the other has gas going to it and barely burning
    Champion:
  • 254 Answers
It would appear that your regulator is not working.
Hope this helps ya
Posted on Jun 22, 2008
When i light the Burner then I lite the grill depending on which on I turn up one of the other the flames goes down on the opsite on e that I tunr
Posted on Aug 25, 2010
Brand new with brand new one pound Coleman canister. Spent hours trying to get it lit. Seems like lp is not coming through. Removed canister and replaced many times. Dont smell lp.
if you got the cannister from the shop with the grill the chances are that the cannister needs filling first as gas bottles are empty when new.
Apr 10, 2015 | Weber Baby Q Grill
I have just purchased a little portable gas grill. Do I unscrew the Coleman Propane Fuel cannister when I am finished cooking or leave it attache? It seemed that my first tank didn't go very far.
To be safe, Yes. Be sure to turn the canister tank is turned OFF before removing it. Also, be sure that when you reattach it, that you open the gas tank valve Very, Very Slowly (Slow Motion, slow). This will prevent the regulator from getting locked up.
Hope this helped and Happy Grilling!!
Jul 19, 2011 | Coleman Grilling
I have a Coleman two burner propane campstove and
Try cleaning the carbon out of the burners.
Jun 22, 2010 | Coleman Gas Grill Stove
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Flames from the coleman gas grill only come out from one side. the other side has worked in the past
No promise! but I had a spider make a big web in one side of mine.. could be anything
Mar 18, 2009 | Coleman Gas Grill Stove
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Coleman Propane Grill Stove 9921-700 Logo
1,222 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
