Question about Philips 47PFL7403D 47 in. LCD TV
Best picture for philips 42pfl3605? how much brightness color contrast ... tanx.
4 Suggested Answers
  • 11 Answers
SOURCE: Picture settings
The settings is on the remote (menu)
Posted on Jul 31, 2008
VOTIT
  • 2071 Answers
SOURCE: Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Posted on Sep 21, 2008
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
Best picture calibration settings
For any TV; irrespective of its brand or type, set the contrast to 70 to 80%; brightness to 30 to 35% will produce a clear and vivid picture in B/W. Set the color to Zero, and check this first. After you have satisfied with the picture in Black/White [B/W], advance the color intensity, according to your viewing taste. This adjustment will depend on individual taste. Anyway, note the skin tone of the news reader at the studio. Take this color a reference. That's all.
Jul 18, 2014 | Philips Televison & Video
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
What are the best picture calibration settings for the sony 4k xbr65x850a tv
Brightness to 40 > 50%, Contrast to 65 > 75% & Color to 30 > 35% must give a good picture. First, try to adjust a good B/W picture, by adjusting the brightness and contrast. After you have got a good picture in B/W, then advance the color intensity, according your viewing taste. Gopakumar Gopalan Google
May 30, 2014 | Televison & Video
Best setting for perfect picture
Brighness 20-30%, Contrast 70-85%, Color to your preference.
Mar 05, 2014 | Durabrand DWT1304 13" TV
What is the correct picture setting for a vizio smart tv model E322AR?
Contrast = 60 to 80%.
Brightness = 40 to 55%
Color = according to personal viewing taste.
Sharpness = 15 to 20%
The best way to tune to a perfect picture is, set the color to Zero first. Without any colour, increase the contrast to at about 65%. Adjust the brightness to get a perfect picture in B/W. Then increase the color, according to your viewing taste. Compare the skin tone of a person. That's all.
Oct 07, 2013 | Vizio Televison & Video
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Best picture settings for 19" philips tv
Brightness set at just half or a weasel hair more. The contrast at 75 to 80% Color at half or one weasel hair more, sharpness at 75%. Sharness is usually the background focus. Tint at half. Actually, I would have to say one of the best TV made is any of the 19" models. They have a rep for really lasting a long....also, the most optimum picture of all sizes made. A note here..sometimes the contrast is called picture, and if you have a cool,warm or normal setting...always go with normal.
Nov 10, 2009 | Philips 19PR19 19" TV
Need help with TV calibration for philips
DNR: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips 47PFL7403D 47 in. LCD TV Logo
400 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
