Question about Panasonic KX-FHD332 Plain Paper Thermal transfer Fax
Panasonic KX-FP153 Copy too dark
Hi, My above model fax machine copies far too dark. Also when people receive documents they are saying they are too dark too. I'm guessing this problem is linked. Any suggestions please?!
Thanks
:o)
    Genius:
  • 2,120 Answers
Try unplugging the power cord and re-plugging. It sounds like your scanner assembly is going bad.
Posted on Sep 26, 2008
Erasing Memory from KX-FHD332
Follow page 65 and 72 of Panasonic KX FHD332 Operating Instructions Manual
Memory full
When making a copy, the document being stored exceeds the memory capacity of the unit. Press {STOP} to clear the message.
Divide the document into sections.
Fax/memory full
The memory is full of received documents due to a lack of recording paper or a recording paper jam. Install paper (page 14)
or clear the jammed paper (page 72).
L When performing memory transmission, the document being stored exceeds the memory capacity of the unit. Transmit the entire document manually
Mar 11, 2016 | Panasonic Office Equipment & Supplies
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Jun 23, 2012 | Office Equipment & Supplies
Panasonic KX-FLB758 is not copying documents properly. Any idea why? If I scan and then print, it is fine but not when I try to copy.
Call 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
Jun 05, 2012 | Panasonic KX-FLB756 Plain Paper Laser Fax
Hi How i can get a user guide (manual muser guide) on line for a Panasonic fax machine KX-FP153 ? Thank's Priore.
http://www.telec.com.ar/img/KX-FP153-158AG.pdf
http://www.panazip.ru/manuals/fax/KX-FP153RU_FP158RU.pdf (russian version)
no english found
Sep 19, 2011 | Panasonic Office Equipment & Supplies
Fax machine saves incomign fax to memory, won't print
your looking for a com journal.. but this machine just says the number you sent it to not the photo of the first page
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
Panasonic KX-FP101 will not copy
theres a handset problem in your unit. try to lift up the handset and firmly set it back to its cradle.if after doing this the tel sign disappears, then you can proceed with the copy otherwise the hook switch of your fax machine has a problem.
Mar 09, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
Document sent is blank for recipient
Hi there check the machine scanner light by putting the original in the feeder and doing a copy. If the printout comes out OK then it either could be the other fax machine you are trying to send it to or you have a intermittent fault with your scanning lamp (Section).
You also must make sure that the original is text face down.
Hope this helps you
Thanks J
Jan 08, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
Incoming documents are too dark
Your thermal head seems to be going bad. No fix for it.
Are they dark when you make a copy?
Dec 26, 2007 | Panasonic KX-FHD332 Plain Paper Thermal...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Logo
337 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
