Question about Panasonic Linear ES 8003 W Electric Shaver
Require replacement for panasonic shaver es8003 where can i get the battries
  • Panasonic Master
  • 1,610 Answers
The original Panasonic batteries are not available to consumers, however, you will find suitable batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Posted on Nov 11, 2010
Battery es8003 replacement
Okies heres the answer
Get your battery from here panasonic shaver battery Cost is $17-$20 range USD with free shipping over $45 at that site.
Goto Youtube and watch this video on how to replace it .
Your blades can be found here Panasonic Shaver PartsGenuine replacement parts inner blades outer foils... at around $25 usd and as for the charger you can find it here Panasonic ES8003 Shavers Spares It's a British site and listed at $28 British pounds.
There are probably other places but those are the first i found that seem to have the item in stock right now.
Cheerio
Mar 09, 2014 | Panasonic Linear ES 8003 W Electric Shaver
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
Where can I find a replacement battery for a Panasonic ES4011 wet/dry shaver? I have looked everywhere. THANKS!
Panasonic does not sell the specialized batteries for their shavers. Your best bet would be to purchase one of the models that replaced it. I have included links to two models below. These are very similar to model ES4011 and use the same shaver head as your model
http://shaveroutlet.com/shavers/panasonic-es-rw30s-mens-wet-and-dry-shaver.html
http://shaveroutlet.com/shavers/panasonic-es4026-shaver-with-er416-nose-and-ear-hair-trimmer-p-699.html
Dec 15, 2010 | Panasonic Sonic-2 ES 4011 K Electric...
My Panasonic Linear ES8003 is losing its charge within 24 hours of being off base. It's over 6 years old. New battery? Can you send me one?
Here on this web site we are not allowed to send people parts for there products.Help solve problems and tell people where to go for parts yes.
Aug 31, 2010 | Panasonic Linear ES 8003 W Electric Shaver
ES 8003 needs new battery, new blades ?
You will find foils and cutters for this model at shaveroutlet.com. See links below
http://shaveroutlet.com/panasonic-wes9080p-cutter-blades-p-85.html
http://shaveroutlet.com/panasonic-wes9081p-shaver-foil-p-86.html
Original Panasonic batteries are not available in the market, however, there is a suitable replacement. You will also find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Apr 03, 2010 | Panasonic Linear ES 8003 W Electric Shaver
Shaver will not hold a charge, panasonic es8003
Sounds like the switch is dirty and not lettingit run ... look at this video on how to clean the switch ... mine would not charge or run until I cleaned the on-off switch.
http://www.youtube.com/watch?v=9b7lf5hqjag
Apr 13, 2009 | Panasonic Linear ES 8003 W Electric Shaver
The batteries in my Panasonic ES8003 need replacing but not sure how to remove them, any help please
Love my ES8003 but the batteries last maybe 1 charge.
I called Panasonic after a fruitless search on the web for batteries and they had none.
They did refer me to Turnpike Appliances which has changed its name or been swallowed up by
smallappliances .com.
If you go to the smallappliances.com site you can search Panasonic men's shavers and find parts for the ES8003. Unfortunately, batteries aren't listed. You need to CALL (1-800-628-3911) smallappliances.com in order for them to special order (meaning you can't return them) the batteries.
Cost of the batteries with shipping is about $42(USD) to my location in California.
To access the batteries, look at the bottom of the razor, there are two very small phillips head screws that attach the base piece of the razor to the body case/internals. The base piece can only attach one way so look at it carefully before unscrewing to make sure you know which way to reattach it. A set of jeweler's screwdrivers is what you need. I actually had better luck removing the phillips head screws with a flat head screw driver...
After removing the screws the base piece should fall away. Lift the razor internals out by grabbing the body case with one hand and, with the other hand holding the foil, lift straight up and out removing the internals from the body case. Note which way the internals came out of the body case so you can put them back in correctly. Gently set the internals down flat on a towel, etc. There are some delicate electrical connections at the bottom you don't want to break. Notice that the two batteries have polarity poles of different lengths. Make sure you note which end is longer, which end is shorter and replace the batteries the same way.
After installing the new batteries, put the razor back together the opposite way you took it apart making sure the rubber seal/plastic trim piece that keeps water out (just below the foil) are seated correctly.
Charge batteries and shave away!
Oct 10, 2008 | Computers & Internet
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Panasonic Linear ES 8003 W Electric Shaver Logo
447 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
