Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
The Zodiac G2 seems to be operating well but the pump seems to be stuggling and getting air in the system. The baskets are clean and the filter has been back flushed and seems ok. A new quartz pool
  • johnandka609 Nov 15, 2010
    Thanks that confirms my thoughts
  • 32,281 Answers
Air is being drawn into the filtering system and the Zodiac won't operate properly.
Check the hose line joints that are on the surface, make sure they are air tight.
Check the 2nd filter basket at the pump, make sure the cover is air tight, check the gasket in the lid.
This lid is clear plastic, if you see a lots of air bubbles when the pump is operating, then air is getting into the system. You need to trace the source of the air leak.
The other possible source of air leak - inside the hose from the Zodiac there is a bladder which inflated when the pump is on to bring the hose to the surface of the water. The end of this badder tube at the filter box may not be sealed properly (the knot at the end of this tube may not be tight).
Posted on Nov 10, 2010
My g4 is not moving
Here are a few things that you can check on this pool cleaner to find out why it is not moving. Make sure that your pump basket and filter are clean and not clogged. Check the diaphragm for blockage or damage. Use your Pool Pulse to determine proper if you flow to the cleaner is low. Low flow will definitely cause the cleaner to slow. Also, check all of your hose sections and connections for air leaks.
Mar 17, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Pressure at about 10psi then drops to zero then back then drops to zero again. Sputter flow of water. Filters and filter baskets have been cleaned.
Try replacing or lubricating the seal on the basket lid. Pool pumps rely on a completely sealed system to work properly. If there is any air getting into the system on the suction side the pump will surge.
Oct 16, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
My barracuda stops moving
There are several steps that you want go through to find the problem with your automatic pool cleaner. Check for air in your system, including hose connections, all fittings at the pump, checking the gasket in pump basket for wear.Make sure that your filter is backwashed and your pump basket is empty. Make sure that your main drain is closed and use your water flow gauge to make sure that you have enough water flow. Finally, check the diaphragm for wear and tear and replace if necessary
Aug 24, 2010 | Zodiac Baracuda Zippy Pool Cleaner
I have an Asralpool self priming pump ref 20601 / serial 094585V It turns on ok but does not seem to be pumping. If left on for 10/15 minutes the pump is obviously getting hot as the water in the...
Is there a place to prime the pump? Self priming doesn't necessarily mean it doesn't need help. If there is no place tp put water in the pump, consider disconnecting the suction hose and fill ith with water, hold the hose up toward the motor to get the most water in you can, then reattach it to the pool and try again.
Aug 12, 2010 | Pool & Spa
I hear it pulsating but it does not move it feels like the suction is too much
You need to use your flow gauge to check for proper flow. If the flow is too high, it will definitely cause the pool cleaner to not move properly. There are a few more things that you will want to check. Make sure that the diaphragm does not have damage or wear and tear. If it does, replace it. Backwash your filter and empty the pump basket. Obstructions or debris in them can cause lack of movement. Check for air in system. Raise individual sections of hose about the water and look for cracks or leaks. If the water level in the pump basket drops or you see excessive air bubbles in the pump basket or coming from the return lines, there is air in the system. Check hose connections, tighten all fittings at pump, and check gasket in pump basket for wear.
Jun 21, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have a Whisperflow pool pump attached to a Polaris Caretaker in-pool cleaning system. When the pump is turned on it pumps a great deal of air through the cleaning system plus the system does not seem to...
there may be some debris at the pump lid oring that is allowing some air to get sucked in. sometimes everything seems to be operating fine until the system gets up to full pressure. perhaps the pump has run dry at some point and the pipe that threads into the front of the whisperflo pump has broken the seal. make sure the pipe is dry and then turn on system. you can use duck tape or squeeze silicon sealer into threaded area this will usually at least allow you to notice that less air is entering the system that way you dont have to cut and replumb parts you don need to. you may want to check any valves that are in the pipes that lead to the front of the pump it is possible that the flap at the skimmer throght where the water comes in at the pool wall tile/water line is sticking up and or is getting stuck which will stop the amount of water needed to enter thru the skimmer basket area once the pump is in full prime this then lets the water drop inside skimmer basket area and air gets sucked into the pump then the process repeats over and over until the flapper is freed or removed
May 09, 2010 | Pool & Spa
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Pool cleaner won't work
Sounds like the filter is getting very dirty and lowering the suction needed for the cleaner to run properly. If that is the case, there are two ways to address the problem. 1. Everytime the cleaner stops, clean the filter. 2. Use a manual vac and cut the pipe that comes off the top of the pump and goes to the filter. By eliminating the filter, you should be able to clean the pool a lot faster. You'll have to empty the pump basket often.
Mar 04, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac pacer
Sounds like diaphragm is ripped
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
272 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
