Question about Daewoo DWC-121R Air Conditioner
Hi, we are working on a Daewoo Split AC, model# DSB-180LHT nad we suspect the receiver p.c Board is processing the commands, as we live in Australia, i am having difficulties in locating a spare parts supplier, if you could point me in the right direction, that would be great
  • Daewoo Master
  • 3,740 Answers
Hi, The Company in the first link below is supposed to be the aftermarket support point for Daewoo. Try here first: http://spares.alliedappliance.com.au/part_enquiry.php
The try this one.
http://spares.bigwarehouse.com.au/price_and_availability.php
Since you did not state any part numbers I am helpless to help you find a replacement. FYI most board failures that I have experienced were condensation / corroson/ water caused. The electrical runs on the boards end up shorting and then take out the PCB transformer and fuse if there is one installed.
Let me now if neither of these companies were not able to help you. I will search again via Daewoo corporate if I need to.
Thanks for choosing FixYa,
Kelly
Posted on Nov 10, 2010
Hi, nad going but no sound from speakers. can get FM but only up towards full volume.
Checker speaker wiring on back for shorts, if okay! the audio drivers and outputs are highly suspect, at this point I suggest a serviceman because of the complexity of the surround sound system.
Apr 20, 2012 | NAD T751 Receiver
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
Hi i have a Daewoo DSB 180LH air conditioner but the previous tenants have lost the remote control, what can i do?
Hi Cladia,
I had exactly the same problem! Fixed it by buying a Universal All In One Air Conditioner Remote. Tried a couple which didn't work, but finally found one which did - the Chunghop K-1028E. I purchased it online for $20 inc delivery to Australia.
Good Luck!
Regards,
Will.
Feb 28, 2011 | Daewoo DWA-146R Air Conditioner
Daewoo split system model DSB-242lhg. Wont work on heat green light is on but no hot air
Is the unit in heating mode? If so, are the filters clean? Have the system repaired if you cannot fix the problem.
Mat
Jul 15, 2009 | Daewoo DSA-122L Air Conditioner
Removal of window winder assembly for 1500 Daewoo
If your in adelaide call a place called new model wreckers in sydney. There service is realy good. i speak to a guy called dave there
Aug 30, 2008 | 1999 Daewoo Nubira
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Right Channel Not Working
I have had the front, left and right channels go out over time. I have fixed all of them, and each time it has turned out to be a cold solder joint. While I love NAD and will continue to purchase there equipment, this generation is plagued with poor workmanship.
To fix the channel going out, I removed the top cover. Back cover and 2nd card from the left (looking at the receiver from the back side). This card handles all of the audio processing. I have found cold solder joints all over this board which has caused channels to suddenly go quite. I have never found a bad component. Also, I have cleaned the interconnect to be backplane (board that the audio processing board connects to) in the case of the center channel going quite.
If you have poor FM reception, the first board from the left (looking at the receiver from the back side) may have a cold solder joint on the coaxial connection for the FM antenna.
Apr 26, 2008 | NAD T752 Receiver
Daewoo DWC-121R Air Conditioner Logo
155 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
