Question about Garmin nuvi 260W GPS Receiver
When i power it on on battery power it opens showing the Garmin sign and after 5 seconds flashes off and them back on and keeps cycling. When I plug it into DC power and my computer it will power up and cycle the same. The functions will not start.
  • 3,267 Answers
A file might have corrupted on the system.
If you uploaded some POI file just before the crash, it might be a defective POI database. You can delete it by booting in test mode (turn device off, press on the lower left corner, keeping pressed turn the device on, wait for the test menu to appear. If the unit stays on, you can connect it to a computer and see its memory, locating the poi.gpi file in the POI folder. Move it on your computer (just to have a backup; one never knows), safely remove and disconnect the USB device from the PC and power cycle the Nuvi).
Assuming it's not the POI, you will have to perform the Firmware Restore on your device (or you might install the newest firmware from Garmin, as well). When in Test Mode (see above), the Garmin Web Updater function should work: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Also, you may try a Master Reset:
http://www.gpsdiscussion.com/garmin-gps/2183-your-nuvi-having-trouble-picking-up-signal-acting-lethargic-do-master-reset.htm
Posted on Nov 10, 2010
When not plugged into auto or outside power, when turned on, will
Sounds like you may have a defective battery. I think that particular device will need to be returned to the manufacturer to have the battery replace.
Apr 01, 2009 | Garmin Nuvi 255 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
112 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
