Question about Microsoft Windows NT Workstation 4 for PC
Operating systems how do operating system works?how do it process?
    Champion:
  • 214 Answers
Hai,
For learning OS and its working
goto the following link and click computer section.
U can learn a lot from there.
http://computer.howstuffworks.com/computer-software-channel.htm
good luck
Raby
Posted on Jun 17, 2008
Describe the difference between competing processes and cooperating processes
The difference is that competing processes in an operating system compete for resources. Cooperating processes share resources, and some even work together to complete the same task.
Sep 25, 2016 | Computers & Internet
Hello...This is ilyas shaikh
Did you set the boot order correctly .
Maybe the attached url will help
http://www.wikihow.com/Boot-a-Computer-from-a-CD
Apr 28, 2014 | Computers & Internet
How to install an os on an old pp2180
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Apr 18, 2012 | Computers & Internet
Windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
hope this helps you
Apr 16, 2012 | Computers & Internet
Black screen on start up with blinking cursor
Chances are, the operating system is corrupt.
Solution 1
1. Restart the computer, before entering the windows, press F8 to open the Windows Advanced Options Menu.
2. To enter the windows, select Last Known Good Configuration - enter. If that fails, repeat the process, select the Directory services restore mode. If that fails, repeat the process, select the Debugging mode.
3. After successfully entering the windows, press START - All programs - Accessories - System Tools - System Restore. Restore to a date when the computer is in normal condition.
Solution 2 (if the above solution fails)
Repair windows operating system with a bootable CD
Windows XP
1. Insert the bootable operating system CD, and restart
2. Perform booting from the CD room - Enter
3. Press enter - F8 - press R to repair the operating system
4. Wait until the process is complete. Finish
Windows Vista or Seven
3. Select Repair your computer - System Restore. If that fails, repeat the process 1, 2
4. Select Repair your computer - CompletePC restore. Restore a computer from CompletePC Backup Image.
Solution 3 (only for Win XP)
When done repair the operating system, drive C is detected: unknown or not formatted, it means the C drive for bad sectors.
To fix hard disk bad sectors, use the software HDD Regenerator bootable CD.
Nov 23, 2011 | Toshiba Computers & Internet
How can i install windows xp on laptop CQ60-104TU without flushing the BIOS
When your operating system stops working correctly, you might need to re-install it. In many cases, when you continue operating the same computer for years, installing and un-installing programs over and over again, sometimes certain operating system files don't work as well as they once did. When that happens, you can also start a re-installation of your operating system. If you use the same operating system for a number of years, it is often helpful to re-install the system software every now and then.
1. Put the original CD or DVD for the operating system in your CD or DVD drive.
2. Shut down your computer and restart the computer. Boot from the CD, if your system asks. This will start the installation process and will pause when a blue installation screen appears.
3. As the screen directs, press the "Enter" key to continue the installation process.
4. Press the "F8" key to continue the installation, agreeing with the Windows Operating System licensing agreement.
5. Press the "R" key on the next screen to attempt the repair process. This process will attempt to re-install all the operating system files that are on the installation disk without bothering any of the customization that you have done to your operating system. This process may take a few hours to complete, but when it completes, you should have Windows XP re-installed and working on your laptop.
I hope you find it very helpful. Best regards.
Aug 15, 2011 | Compaq Presario Notebook
Blue screen error STOP: c000021a {Fatal System Error} The windows logon process System process terminated unexpectedly with status of 0x0000005 ( 0x00000000 0x00000000). The system has been shut down.
It appears that your Windows Registry is corrupted. You can try to use a Registry repair utility like CCleane to fix it. If that doesn't work you will have to reload Windows OS (Operating System). For more info no this error code Google "c000021a".
Feb 07, 2011 | Dell Computers & Internet
What program would I need to Run an order-processing application that requires a multiprocessing operating system. The application will take orders from customers over the Internet, process the orders, and...
" an order-processing application that requires a multiprocessing operating system " - the answer is in the requirements, a multiprocessing operating system. All modern OS's are multiprocessing, but if your store will get a decent traffic for efficiency reasons you will have to use a server OS (a Windows or Linux one, depending on the exact form of the program)
Jun 01, 2010 | Microsoft Windows XP Professional
What is bootstraping?
Bootstrapping means
  • "To load and initialise the operating system on a computer"
word comes From "to pull oneself up by one's bootstraps"
Check this detailed explaination at Wikipedia and at Khmere.
Feb 02, 2009 | Microsoft Windows Vista Ultimate Edition
System tray,Start button not available
Goto Taskmanager process tab and check which process is using your memory,kill the process and also note whts ur processor usage?
Try to boot in safemode and check whether your start button is working or not.
goto run type msconfig and in startup tab disableall and reboot the system.
Diagnose these things and post it back
Oct 31, 2008 | Computers & Internet
Microsoft Windows NT Workstation 4 for PC Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
