Question about Garden
Went to start it, and snapped the pull start cord. Trying to pull it apart to replace it but cant get the front gaurd off from the motor to get to the cord.
    Brigadier General:
  • 4,088 Answers
Usually, the whole starter mechanism can be removed from the left case by taking off several screws. The spool will be revealed when looking at the rear of the mechanism. Remove the rest of the starter cord from the spool and handle, then turn the spool CW about 2-turns, and wedge it so that the spool doesn't unwind again. Fit a new cord end of the same dimension and about 3-1/4 ft (1-meter) in length into the spool slot/hole, melt the end, and tie an overhand knot in the end. Wind the cord CW until you have about 8" left--poke the cord out of the cord port, push the end through the handle, melt the end, and tie an overhand knot. Stuff the knot into the handle bore, release the spool wedge, and pull the cord through several times to make sure that it works without binding in the spool and retracts fully. Reinstall the starter and test on the engine. Hope this helps!
Posted on Nov 10, 2010
HOW DO I REMOVE FRONT COVER ON KENMORE SEWING MACHINE
1. Newer machines are more difficult. You will have to find the hidden screws behind little plugs. You just pull out the plugs using a very thin screwdriver.
2. The next trick is to pull the machine apart. Their are snaps to unsnap by pulling. Pull a little on areas to see where the snap areas are holding parts tightly together. You will have to pull hard to get these areas unsnapped. You will get it but it takes a little work. Don't pry with your screwdriver or you will ruin the appearance.
3. The older machines are easier. Just unscrew and the parts come apart.
4. Whichever you are working on use some masking tape to mark the screws or hold the screws in the holes they come out of. If you don't do this you may have a problem when it comes time to reassemble.
Sep 03, 2015 | Kenmore Sewing Machines
How To Replace The Pull Cord
The motor and trans do not come apart to replace the pull cord, just remove the cap and rewind the spool then replace the cord. Not a lot of disassembly required, just a couple of small bolts.
Nov 10, 2014 | Garden
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
How do you get the deck belt back on the pulleys? 20 hp-46'' deck
It helps to remove the belt gaurd on the left side of the deck. The belt gaurd on the drive pulley ( motor crank) can be pulled out and moved by hand- lay on left side of mower and reach across and pull right side of belt gaurd from hole in frame and swivel away. Once belt is installed slide gaurd back into hole. all other pulleys the belt can just be spun on past the gaurds. Be sure to replace all belt gaurds and saftey devices as they came from the factory.
Nov 24, 2009 | Mtd Garden
Pull cord stuck to motor housing
Ok You have to release the engine brake. BY pulling down the bail to the handle as if you were going to start the engine. Hope that helps.
Oct 21, 2009 | Garden
The Pull cord was jamming. I took it apart and
the rope and spring both have thier respective place in the housing for thier mountings they can be rewound by hand and reassembled with success,hint oppisite end of spring has a anchor point on the housing while one end is secured by a cup like screw mounting,to create the retracting force for retrival of the pull start rope its tricky if haven't done it before but you learn by trying Good luck Steve
Oct 01, 2009 | Homelite Mighty Lite Lawn Trimmer
92 buick century power antenna motor wont shut off
Well, even if you pull the connector (under carpet) apart with gray white and green wires(ones seen going to motor from door gap when opened) it still doesn't stop. next access point is from behind mud gaurd in wheel well. If I can't disconnect it from there I will just cut the bloody wires.
Mar 17, 2009 | 1992 Buick Century
My timing belt has just snapped on my mitsubishi car how would i go about replacing it?
Hi there. If your timing belt snapped well the car was idled up at road speed there is a good chance it did serious damage to valves or pistons. I cant gurantee it but unfourtiantly there is no good way to tell without pulling the motor apart and checking the valves and pistons, etc. If the car was just idling when it broke, you may be all right but once again no way to be sure without tearing it down and having it checked. If you decide its worth trying to replace the belt you would want to get a shop manual such as haynes or chiltons for the procedure because this is a big job. More than likely the easiest way involves pulling the engine.
Mar 15, 2009 | 1997 Mitsubishi Eclipse
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
