Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Pt456c12 wont come on blinks green at the on off light
We turn it on and the green on and off light just blinks on and off but the tv does not come on we hear the fan but no picture, we had moved it to another location when this started. the lamp looks good and is not too old. what do you think could cause this? how do I tell if the lamp has gone bad or could it be another problem.
I had the same problem.  I fixed it replacing the thermal fuse.   You can get the thermal fuse from Radio shack.   Hope this helps.
Posted on Mar 06, 2009
  • 927 Answers
Good Day, teagues;
It sounds like a bad lamp. Lamps normally have a 5,000-hour life. Looking at the lamp can tell you if it’s bad if it looks burnt, but not always. Your Panasonic TV is also known for having failure of the ballast, which turns the lamp on. 95% of the time it’s the lamp, trouble shooting the ballast is a little more challenging.
The lamp replacement is a very simple process; instructions are in the TV’s owner’s manual. Call the factory, they will send you the lamp to your home with complete detailed instructions.
Good Luck, Big Irish.
Posted on Jul 09, 2008
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
GREEN LIGHT COMES ON BUT TV WONT LIGHT UP AND WONT TURN OFF
Call the number on your TV manule and tell them you probley have a Loos Fuse in your Tv
Jan 05, 2010 | Apex Digital LD1919 19 in. LCD TV
Tv wont turn on
The green light flashing indicates an error code, plasma tv's cannot be repaired at home without the right equipment and service manual, the fault could be power supply, processor or virtually anything, what technicians look for is the frequency of the blinking and the time between sets of blinks, this normally gives the tech a code that enables them to go to the right area, the only thing anyone can tell you is that the processor is probably ok, you really need to get a quote or count the blinking and the timing eg: "blink blink short pause blink), and repost the fault, then we can possibly tell you where to look...Phil
May 18, 2009 | Akai PDP4206EM Television
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
