Question about Garmin Edge 305 GPS Receiver
Garmin Edge 305 switches off during use while mounted on the Garmin bike mount. If kept in pocket it works fine. Does it have something to do with the vibration from the bike while on the bike mount?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Could be yes. There are contacts inside the device that become sensitive to vibrations after a while.
I have seen on Internet that it may also be due to USB plug that acts on these contacts.
Anyway in this situation there is no other way than opening the devices and soldering contacts or adding wires to replace these contacts.
As opening device is not at all easy, I recommend you send your device to Garmin support.
Otherwise please check the relevant procedure on the internet
Posted on Feb 23, 2011
Where can i get a new screen for my 305 edge
Hi Gary,
Your best bet on this would be to allow Garmin to handle it. These devices are so small and require steady hands and precision tools to perform the repair work. I checked out Garmin's site for "Out of Warranty" repair rates (even if under warranty - it wouldn't covered for the kind of accident it suffered), and the good news is: for just $79, it will be either be repaired or replaced with a factory "Newly-Overhauled" 305 GPS. It will also be updated with the latest software and come with a 90 day warranty.
You can arrange for this repair completely online by following the instructions on this page:
http://www8.garmin.com/support/outofwarranty.html
I hope this helps & good luck!
Nov 16, 2011 | Garmin Edge 305 GPS Receiver
Can i order a new LCD for a garmin edge 305 and mount it myself?
Difficult to open it. If you do, warranty is over. There is a web site explaining how to open device :
http://blog.mtbguru.com/2008/11/06/surgery-on-the-garmin-edge-305/
Aug 10, 2010 | Garmin Edge 305 GPS Receiver
My edge 305 turns off intermittantly during rides and is not mapping the routes I ride completely
This is internal problem due to contacts that are getting dirty or spaced because of too much pressure on the USB port.
Better way is to unmount the device and solder wires in place of gold contacts.
Unmounting device is not easy, see following link
Jun 10, 2010 | Garmin Edge 305 GPS Receiver
The device is blocked
Hi Have had this happen to me also, try pressing the mode and reset at same time also try lightly tapping frame of garmin on desk (easy though). if this still fails put it on your bike and go for spin??? hope first suggestion works as it did fr me
Mar 23, 2010 | Garmin Edge 305 GPS Receiver
My Garmin 305 edge does not work correctly
Normally with Garmin sat-navs you have to switch the on/off button off and hold for around 8 seconds to reset the device
Feb 01, 2010 | Garmin Edge 305 GPS Receiver
My edge 305 doesn't always pick up sallelite. I
Hi If you have the time and patience then log onto garmin and download the webupdater then join the garmin site and plug in your 305 garmin dashboard will update for you and possibly fix it, other than that you will have to send it to garmin, if its still in warranty, 75 dollars if its out of warranty nty
Nov 18, 2009 | Garmin Edge 305 GPS Receiver
I have an edge 305 and use it mountain biking. O rough trails it shuts down. I think it's a loose conection inside the unit. When I stop it will turn right back on.
It is a connection problem inside the device. If it is under warranty you should send back to garmin, otherwise you can apply trick as described at following site :
Oct 20, 2009 | Garmin Edge 305 Bundle Includes Hr And...
Garmin Edge 305 will power off in a min or 2 riding in afternoon
This is a generic problem with the 205 and the 305 go to MTBGurublog and look up 305 problems there is a blog that shows how to open and fix it
Jul 07, 2009 | Garmin Edge 305 GPS Receiver
305 Elevation Problem
Sorry to have to break (no pun intended) this to you, but I have had two units do this. Once this problem starts eventually the Elevation field will display and stay at 65616. The problem is with the barometric altimeter and cannot be fixed without sending the unit to Garmin. When you call Garmin technical support, they will have you do all sorts of resets - be patient - eventually they will concede that the unit is busted and give you an RMA. Both times this happened was after the unit got a little roughed up (one time dropped it, the other time was mountain bike tumble) - evidently the altimeter is the least robust part. Good luck.
Jul 28, 2008 | Garmin Edge 305 GPS Receiver
Forerunner 305 won't charge
Question: My Edge or Forerunner 205/305 won't power on. Is there a soft reset that I can do?
From the Garmin web site.
--------------------------------------------------------------------------------------------------------------------------------------------- Answer: If a Forerunner or Edge 205/305 is unable to power on, a soft reset can be performed to un-freeze it. This will not erase any user data and is most effective if the device is connected to the computer while performing the reset.
To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version
May 26, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
393 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
