Question about Motion Computing AP42332 LE1600 Notebook
I CANT FIND THE UP OPTION TO MDOWNLOAD A 30GB RAM TO COMPUTER
  • joecoolvette
    joecoolvette Nov 10, 2010
    victor_okpa what are you talking about? Ram Memory? You can't download Ram Memory. You have to physically add Ram Memory with Ram Memory modules. (And you won't be upgrading to 30GB of Ram Memory) Post back in a Comment.
Power problem
Remove the main battery and try again, next have the power supply checked for correct voltage, if okay sub out the ram memory one at a time to see if you can start it. The DC jack in the laptop is a common source of trouble, at this point computer must be dismantled to address the situation.
Jun 04, 2012 | Dell Latitude C640 Intel Pentium 4-M...
I have a latitude D600 and I am now getting the 'disk read error' after installing a new larger than 137 GB hard drive. I know (now) I need to upgrade the BIOS to see the larger hard drive, bu
Unless Dell has the upgrade for the bios to include the larger hardware you are going to be in trouble, I would go online to Dell and check for upgrades to your model if they still support it. The other option is contact customer and technical support to see it they can give you a alternative solution.
Mar 20, 2012 | Dell Latitude D600 Notebook PC - Intel...
Elitegroup A530 can support max ram is how much?
Elitegroup A530 is an old model.
It has a built in 128 ram. but it can support 256 ram, 30gb on memory
Check this site for more information;
http://www99.epinions.com/specs/pr-ECS_A530_Combo_Desknote_PC_Desktop
Hope this helps. Thank you for using Fixya!
Apr 19, 2011 | EliteGroup A530 Notebook
P 3 with 256 sd ram,not able to install xp
It is struggling to install a driver. reformat the hard drive when you have the option (Fat 32 or NTFS which is better) and try again. If it still fails then remove usb devices except for keyboard and mouse if they are usb. Remove and add on cards and install on a basic system. If the install still fails then you have a corrupt hard drive or corrupt install disk. you can start the computer using the install disk and selecting recovery console to give you an dos screen. At the prompt type chkdsk and let it look for errors.
Jan 06, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
A4tech camera
Try here
http://www.a4tech.com/ennew/support.asp
Sep 23, 2009 | A4tech PK5
I cant synchronize music to my 30gb Zen Xtra
you probably need the disk it came with and if you cant find it look for it on the internet and you might wanna try a program called WINAMP to transfer music to your ipod
Jul 24, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
I cant download
Well, you need to check the device manager for the status of the network adapter (atheros). And if you are able go online, then is should'nt be an issue. But still you want to get back your drivers for the atheros adapter, and if you are using Win XP OS, then you easily reinstall the drivers for the adapter.
Color of the eth cable does not have any significance as long as it is an eth cable which correctly fits in the eth port.
Dec 21, 2008 | Gateway Wireless-B Router (wbr-100)
Ipod 30gb has block
Do you have the option of reformatting the ipod with out the code?
If you can, try and reformat the ipod through itunes.
Jaxon
Nov 11, 2008 | Apple iPod MA446LL/A MP3 Player
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop http://www.dealtime.com/xPF-Compaq-Refurbished-COMPAQ-P4-M-1-8GHZ-256MB-30GB-14-1-TFT-CDRW-W-XP
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
Motion Computing AP42332 LE1600 Notebook Logo
23 people viewed this question
Top Motion Computing Computers & Internet Experts
David Payne
David Payne
Are you a Motion Computing Computer and Internet Expert? Answer questions, earn points and help others
