Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer is not working properly. after giving print command, a crrr voice is there and occures error no. 5100
  • 386 Answers
Hi Good day!! It is a waste tank error 5100 you need to reset your waste tank
Please follow this:
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Thank you for using FixYa
Please accept if my solution helps you
Posted on Nov 10, 2010
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
Error occured/error 5100
just reset your printer eeprop by software.type generaltool for canon mp160 and googlee it.run software,connect your printer and reset your printer eeprom.
Jun 17, 2012 | Canon PIXMA MP160 All-In-One Printer
What does error 5100 mean. When I switch on a plain piece of paper comes t hrough before I give instructions to print ( set for black print). Then t his happens everytime i command to print.
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out
Feb 02, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Use Printer Offline: Error Processing Command
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jun 07, 2010 | HP DeskJet 6540 InkJet Printer
An error 5100 always occur in my pixma iP1980 whenever i print a
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
May 25, 2010 | Canon Office Equipment & Supplies
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Regarding service error 5100 in canon ip1880 printer
1. Try to reset the ink counter by iptool software (sometimes it help)
2. Unplug the usb cable and then turn off and on your printer for a few times.
service error 5100 seems like indicating of mecanism exhausted or out of buffer ram in the printer. You should reduce the amount of pages to print at one time.
Good luck.
Jan 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
5100 error with canon i255 printer
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Dec 24, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Hp printer does not print out when command is issued
not specific enough, is the error on the pc or the printer?
in any case here is the manual check here for connections and trouble shooting.
http://www.retrevo.com/s/hp+6210+manual
Dec 06, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
