Question about Dishwashers
Doesn' cycle power is on except drain cycle goes, clean light blinks 7 times
Clean ligfht blinks 7 times
    President:
  • 2,712 Answers
Check this link for more info:
http://www.repairclinic.com/0088_9_1.asp
Posted on Jun 17, 2008
Dishwasher will operate only 10 min before stopping cycle
Check for places food could get stuck and clog the workings, including the drain hose.
Nov 24, 2013 | Kenmore 24 in. 16302 Built-in Dishwasher
The "clean" light blinks 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
Clean light blinks 7 times and won't let us start a cycle. Then it continues to do that
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 08, 2011 | Kenmore 24 in. 17029 Built-in Dishwasher
Whirlpool GU 2400 : "clean"
Hi
Daniel
May 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Does not go thru dry cycle, clean light blinks 7 times
clean light blinking is a tricky problem to find and cure can be a few different issues.heres an edited down version of official manufacture explaination,its been an issue (I would call manu for assisstance in repairing this further)
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down dish washer. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The Proper incoming water temperature should be between 120°- 140° F.
Possible causes of insufficient temperature rise would include wires off at thecontrol, heating element, thermistor,inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Feb 27, 2008 | Kenmore 24 in. 16034 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
