Centrex ctw60519 washer. Wash cycle not working as center plate part has come loose and spins freely all the time. If I tighten the screw that holds it in place it functions properly for about a minute before coming loose again! Is there anyway to stop this one screw (doesn't seem to be a very well designed system) from loosening itself?
  • timmyjaudio Nov 11, 2010
    Thanks Silverdragon, thought it was a bit odd one screw did all the work! I'll contact a service center and get it looked at. Cheers
    Helpful information, centre screw just part of larger assembly that needs servicing.
  • 12,061 Answers
That screw isn't all that should hold that assembly together what has happened is the locking "Dogs" have broken and this is stopping it, the screw is more of a "Keeper" it's not meant to bear the full force, in any event, it is quite a difficult fix. Your best bet, will be to get it looked at by an authorised service center. Get a service man to call and ask them for a "Quote" before allowing any repair work to be undertaken. This isn't an expensive repair.. however it is always prudent to get a "Quote" in any event.
Posted on Nov 10, 2010
Machine rocks, all four sides, removed and oiled clutch bearings, tightened the belt, still rocks and errors out no matter the size load, machine is balanced. ?
I feel you still have a clutch problem... Did you try this test before you cleaned up and re-lubed the One-Way Roller clutches in the Clutch pulley?
From my Clutch Fix post;
Let's demystify dC and uC error codes plaguing the FAV6800A and the LCD Flavor FAV9800A
One last step before you clean up those pesky Clutch Pulley One-Way Roller Clutches/bearing.
Holding what I call the Spinner Shaft coupler first picture. Insert that coupler into the Clutch One-Way Roller bearing plate.
Now while holding the Spinner Shaft Coupler with one hand as I show in the second pic with your other hand rotate the white bearing plate in the CW direction around the Spinner Shaft Coupler.
The One-Way Roller Clutch bearing plate should rotate freely in the CW direction this is the wash/agitate direction.
Now rotate the One-Way Roller Clutch bearing plate in the CCW direction it should lock up solid.
Most times the One-Way Roller clutches will slip did it slip for you? This will cause the agitator shaft to move slightly causing slight tumbler rotation while the wash basket begins to spin up unbalancing the wash load causing big time wash tub swings and those pesky unbalance error codes.
The Control Board sees the TDS analog voltage swings out of design limit and shuts down the spin cycle. If the TDS was not working as designed the machine would walk across the room and unplug itself or self-destruct.
The Control Board programming will try several attempts to redistribute the wash load and when the magic number of wash load redistribution attempts has been reached the Control Board signals a dC or uC error code to the display. I believe the FAV9800A signals a text error to the display i.e. "unbalance condition?" or something like that.
Anyway I thought you might want a little more insight into just what is going on here. A very poor Clutch design by Maytag. Mine failed at the 3.5yr mark of service and I was not about to trash a $1K machine. Sorry to say I feel number of them do make it to the curb on bulk trash pickup day.
I call this the Spinner Shaft Coupler. Not sure what Maytag calls it.
This is the One-Way Roller Clutches/bearing.
While holding the Spinner Shaft Coupler with one hand rotate the white One-Way Roller Clutches/bearing plate in the CW Wash/Agitate direction with your other hand. It should rotate freely in the CW direction around Spinner Shaft Coupler.
Now rotate the white One-Way Roller Clutches/bearing plate in the CCW direction the Spin Cycle direction. It should lock up and not rotate CCW around the Spinner Shaft Coupler. If it does the tumblers will rotate slightly and cause the wash basket load to go off balance as the wash basket spins up.
If the TDS is working as designed the machine will fail in Spin Cycle with dC or uC error codes. If the One-Way Roller Clutches/bearing can be cleaned up and re-lubed you could be back in service with no cost.
If so what were the results?.................Rich
Oct 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
Centrex top loader washing machine Model # CTW60519 6kg Auto Washer. When washing the center screw holding the base plate unscrews. The base plate lifts and the clothes are not washing clean. We have...
The part that the screw holds is turning independently of the screw. Remove it and inspect for torn splines or other motion locking device. Repair or replace the part using Loctite on the screw threads.
Sep 14, 2009 | Washing Machines
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Washer stops after wash cycle. Won't empty water, won't spin.
the lid switch is defective or the lid or door screws on left & right side are loose tighten and or replace. nbcrca:)
Apr 11, 2009 | Roper RAS8244KQ Top Load Washer
Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Centrex washing machine ctw60519
The agitator is only stiff. Do not lift from one side only.
Loosen the centre with some CRC, spin by hand a few times. Then place a hooked pice of strong wire under tow opposite edges and lift.
Sep 16, 2008 | Washing Machines
Knocking Whrilpool Duet
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub. However, if your machine is knocking like you say it is, it could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped. Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin. To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble. More than likely, though, the drive belt would slip off. I have also seen where the hole in the center of the drive pulley starts to "round out". The hole is not perfectly round and has to flat sides. Sometimes over time the drive shaft will start to slip around the flat sides, causing the pulley to rattle during the spin cycle. If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out. Now this should be a noticeable metal on metal type feel. Not the normal motion of the wash tub moving up and down from the motion of the shocks. The tub bearing is not a cheap (or easy) fix. The entire back section of the rear outer tub shell has to be replaced, because the bearing is molded into the plastic. Check all the easy things first. Let me know if this helps.
Jun 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
