Question about Kitchen Ranges
G-five t580 3,6,9,# are not working of keypad
Swich on to cuntinew 3.......
Posted on Dec 29, 2010
What is the procedure for programming the key pad on the door to unlock the car?
  1. Locate the permanent factory remote keyless entry code in your car's owner's manual or by contacting the dealership.
  2. Enter the factory code on the keypad and press the "1/2" button on the keypad within five seconds to start the programming sequence.
  3. Enter a new five-digit code into the keypad within five seconds.
  4. Wait for the locks to cycle once to confirm the new code was successfully programmed.
Feb 24, 2011 | 1995 Ford Taurus
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
Feb 09, 2011 | 2002 Lincoln LS
Just purchased a 2003 mountaineer from a used car dealer and they don't have the manual and the alarm doesn't work. How do I get the factory entry code?
the keyless entry code is on the module and in the module memory. A dealer can extract the code ( about $50). You can access the owner manual on line at motorcraft.com, pro center, tech info, owner manual. I have one for $7 plus postage. let me know. Also, look for a plastic credit card in teh glove box with the code on it. The module should be under the dash, driver side I think.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it overwrites the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system now responds only to the factory set code.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad flashes during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after one minute of keypad inactivity.
Unlocking the Doors and Liftgate with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
To open the liftgate window glass, enter the factory set code or the personal code (driver door unlocks) and press the 5/6 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time
Dec 21, 2010 | 2003 Mercury Mountaineer
G five u800 keypad problem 2,5,8,0 cal butan not work track missing plz help me any solution
RESOLD IT
WORKED 100%%%%%%%%%%%%
OK ITS NOT KEYPAD IC PROUBLEM
BECOS THERE ARE NOT KEYPAD IC
IDRISH 911
Oct 09, 2010 | Cell Phones
Micromax q3's keypad is not working
Aug 01, 2010 | Cell Phones
How do I change the code for key less entery on the key pad on door
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5 digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
  • 1. Enter the factory set code.
  • 2. Within five seconds press the 1-2 on the keypad.
  • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
  • 4. Press 1-2, 3-4 or 5-6 to indicate which of the three personal entry code positions you wish to use.
  • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
  • If you program a code to a position that already contains a set code, the previously-set code will be erased.
  • 1. Enter the factory set 5 digit code.
  • 2. Within five seconds, press the 1-2 on the keypad and release.
  • 3. Press and hold the 1- 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5 digit code will work.
Good luck (remember commend and rated this).
May 03, 2010 | 1996 Ford Explorer
How do i reprogram keyless entry codes
door pad keyless codes?
in owner manual, enter permanent code and then press "1" and enter personal code, then press "1" again. Then both codes will work.
If you don't have manual, go to Motorcraft.com and click on technical resources and click on your year owner manual.
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within five seconds of the previous button press.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code. To erase a personal code, carry out the following procedure:
The system will now only respond to the factory set code.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad will flash during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after any of the following events:
  • one minute of keypad inactivity
  • the keyless entry remote transmitter UNLOCK button is pressed
  • the ignition is turned to the ON position.
Unlocking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Dec 01, 2009 | 2004 Ford F350
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    Auto door locks
    To activate the autolock feature, use the following steps:
    1. Enter the five-digit permanent entry code into keyless entry keypad (14A626) .
    1. Press and hold the 7/8 button on the keyless entry keypad within five seconds of entering the code.
    1. Press and then release the 3/4 button within five seconds of pressing and holding the 7/8 button.
    1. Release the 7/8 button on keyless entry keypad within five seconds of releasing the 3/4 button. To deactivate the autolock, repeat the above sequence.
    Dec 17, 2008 | 1995 Mercury Cougar
    How do i change touchpad code on 2007 edge?
    Programming a personal entry code and keypad association to
    memory seats and mirrors (if equipped)
    4. To associate the entry code with a memory setting, enter a sixth digit
    to indicate which driver should be set in a memory recalled by the
    • Pressing 1 • 2 recalls Driver 1 settings.
    • Pressing 3 • 4 recalls Driver 2 settings.
    • Pressing other keypad buttons or not pressing a keypad button as a
    sixth digit does not set a driver and will not recall a memory setting.
    Note: The factory-set code cannot be associated with a memory
    setting.
    5. The doors will lock then unlock to confirm that your personal keycode
    Tips:
    code.
    1. Enter the factory set 5–digit code.
    2. Within five seconds, press the 1 • 2 on the keypad and release.
    3. Press and hold the 1 • 2 for two seconds. This must be done within
    All personal codes are now erased and only the factory set 5–digit code
    will work
    Oct 10, 2008 | 2007 Ford Edge SEL Plus
    Kitchen Ranges Logo
    110 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
