Question about Panasonic Cameras
Need to transfer pictures from built-in memory card to computer.
    Genius:
  • 1,177 Answers
Remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
Posted on Nov 10, 2010
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
Jun 27, 2014 | Nikon Coolpix 4100 Digital Camera
Transfer pictures
Two choices:
You can remove the memory card (if any) and connect the camera to a computer using the USB connection.
A better method is to use the camera's Copy command to copy the pictures from the internal memory to a memory card, then plug the card into a card reader (either built-in to the computer or connected via USB) and then transferring from the card to the computer.
Once either connection is made, the camera or card will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Nikon Transfer or Picasa.
Dec 03, 2013 | Nikon COOLPIX L810
Transfer pictures from built-in-memory to computer. how? i have a Panasonic Lumix DMC-Ts2. I herd i need to copy from built-in memory through set-up menu, but i am not clear how!
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Sep 01, 2011 | Panasonic LUMIX DMCTS2 / DMCFT2 Digital...
Copy pictures in built in memory to memory card
You have to connect to a pc, transfer the pictures to the computer, then you can transfer them from the computer to the memory card file on the camera.
Jul 30, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Jun 16, 2011 | Olympus Cameras
How do you put your pictures saved onto your camera onto your memory card?
If you saved the pictures to your cameras built in memory, chances are that you cant transfer the pictures from the camera straight to the memory card. You have to FIRST transfer them to your computer and THAN from your computer to your memory card.
Mar 08, 2011 | Cameras
My M1063 is not transfering all pictures--I checked transfer all and remove from camera, so now I do not have pictures I took. Could it be the memory card? How often do you need new memory card? Thanks
Some cameras have a built in memory bank inside the camera other than the memory card. Your pictures may have been stored in there instead of the card. Check your user manual to verify if it has the built in memory. In order to down load these pictures you will need the USB cable that came with the camera. The memory card can be used several times. I recommend formating the card if you want to reuse it again. The card does not go bad that often.
Nov 01, 2010 | Kodak EASYSHARE M1063 Digital Camera
How to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
Mar 31, 2010 | Kodak EasyShare DX6490 Digital Camera
How do I retrieve photos from my built in memory storage if I don't have a camera to computer hook up wires?
Put memory stick in camera, power up and press Menu on camera, select Copy option and press OK
That will copy photos from internal memory to memory stick.
Jun 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
Oct 05, 2008 | Nikon Coolpix 2000 Digital Camera
Cameras Logo
239 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
