Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
I have 500GB Roco (Toshiba) external hard drive... It was not dropped or physically damaged. My desktop and my laptop don't recognized it anymore. What seems to be the problem and how can i fix it? Thanks.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 10, 2010
I have a 500gb roco toshiba external drive. the light is on but it won't read. i tried to change it's cable but still it won't work. how can i fix it?
try and listen to the drive when plugged in, if you hear a faint skipping noise. i suspect it is a fault internally on the reader.
if you have a reciept usually the manufacturer will exchange this. as a repair is very tricky!
Jan 23, 2012 | Toshiba Computers & Internet
Windows xp not recognize external hard drives
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery software.I had succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.
You can download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to get it fixed.
Nov 05, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer do not recognize the toshiba roco HDD
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from external hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Toshiba 120GB USB 2.0 Portable External...
I dropped the external Portable Hardrive (WD 500mg) and now it wont show any files that are on it. Is there any way to recover what is on the harddrive???? Jane I have tried plugging in and viewing but...
Hi Oscarmegs,
Your data on the hard drive are lost due to physical damage.But don't worry,you can recover data from hard drive with data recovery software.I have succeed with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage etc.
Anyway,download a trial version and scan your hard drive for free to preview whether your files can be recovered. http://www.any-data-recovery.com/index.htm
Jun 20, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
I HAVE ROCO HDD FROM TOSHIBA 500GB HARD DISK,I WAS USING PAST 8 MONTH,NOW I FACING THE PROBLEM IN MY HARD DISK,WHEN I CONNECT HARD DISK TO PC,WE FOUND SOME NOICE IS COMING(LIKE TIMER SOUND) AND MY DRIVE...
The HDD is damaged due to bad sector. It has to be replaced, even in service center they will not service the HDD. They will send for replacement to head office. Every HDD comes with a minimum of 2,3 or 5 Years warranty, you can get it replaced. But you cannot recover data from it.. If you try to recover data by giving to any local service center it will void your warranty.
May 14, 2011 | Toshiba 120GB USB 2.0 Portable External...
Sony vaio not recognizing external hard drive
PLEASE GO TO CONTROL PANEL, CLICK ADMINISTRATIVE TOOLS, CLICK COMPUTER MANAGEMENT, ON LEFT PANE, UNDER STORAGE, CLICK DISK MANAGEMENT, WAIT A FEW SECONDS, MAXIMIZE PAGE,THEN SEE IF YOU CAN SEE IT. IF IT SAYS UNALLOCATED SPACE, RIGHT CLICK ,YOU WILL HAVE TO FORMAT USUALLY "NTFS". IF IT DOES NOT SAY UNALLOCATED SPACE, THEN RIGHT CLICK AND MARK PARTITION AS ACTIVE. .........HOPE THIS HELPS........JEFFXC
Jan 25, 2011 | Western Digital My Passport Essential...
My computer isn't recognizing my new Toshiba Roco 250 gb external hard drive
If it is new and has not worked at all, you should try using it on another computer that, if possible, has a different operating system. My first option would be to create a partition using a 3rd party partition creator.
Dec 25, 2009 | Toshiba 120GB USB 2.0 Portable External...
Seagate Freeagent Dropped
Unfortunately what you are describing is a damaged platter inside the hard drive. You may be able to get a technician to recover some data but generally this means the drive is gone forever.
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
1,002 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
