Basket on washer shakes
When my washer starts spinning, its fine. as it starts spinning faster, it starts making a lot of noise. the basket seems to be shaking from side to side. i dont know what it may be.. please help!!
  • princess9406 Jun 17, 2008
    Thanks! I really hope that works.
    President:
  • 1,294 Answers
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Posted on Jun 17, 2008
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Whirlpool model #WFW9150W front load washer. Washer makes lots of noise when operating
If it sounds like a freight train in spin cycle most likely it is your bearings. If it makes a clunking noise during the wash cycle you have a broken support. The best way to tell is to spin the basket by hand and listen for the noise. Check to see if the basket is making circles and not ovals. Pull back the rubber seal and look signs of the basket rubbing against the outer plastic tubs. If is either one of these it is cheaper to buy a new washer than to fix it. Fixing it involves rebuilding the machine. If it only makes the noise when it starts to drain you need to check your pump for foreign objects.
Jul 12, 2011 | Whirlpool WFW9150W Front Load Washer
Im able to start a load, water fills, washer agitates and rinses just fine. However, once the spin cycle starts, the washer starts to make an extremely loud noise (similar to when it is off balance) and my...
If you can move your basket up and down your spinal is broke at rear of basket..You would need rear tub and inner basket for that repair......If this helped please vote need more help please ask...
Feb 03, 2011 | Kenmore 24032\24036 Top Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Sep 01, 2009 | Kenmore Washing Machines
Basket won't move-noise
do you notice if it agitates?
if it doesnt agitate it is just a simple coupling
if it is making a humm noise its the motor
if a LOUD rumble ONLY on spin cycle, its the basket drive assembly and the clutch.
May 29, 2009 | Whirlpool LSQ9610L Top Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Washer makes noise at start of the Spin Cycle
its your basket drive or sometimes called brake spin tube also comes with new clutch, ,transmissions wouldn't make that noise in only beginning of spin. your on your way to being a repair tech good job
Nov 10, 2008 | Kenmore 22422 Top Load Washer
Rear bearing noise when drum rotates
If the rear bearing is bad it will require the replacement of the entire rear tub shell. This is because the bearing is molded into the plastic and cannot be replaced separately (I know, its a stupid design). Sometimes additional damage can occur and the inner spin basket and front shell may also need replaced. In addition, what may seem like a bad rear bearing, might be a broken tub support on the spin basket. In a nutshell, you may have to replace both tub shells and spin basket at a minimum. With parts and labor the repairs could cost $600-$800. If you have no extended warranty or service plan coverage, it may not be worth the effort to repair due to the excessive cost. Sorry...I wish I had better news for you. I hopes this provides you with some answers.
Oct 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
