Question about Xante Ilumina Digital Color Press Printer
Please what can I do to work the machine that says fatal error 133;
  • 24 Answers
133 relates to the cyan LED sensor, infact most likey it is the actual Cyan Image drum.
make suer the LED above the Cyan drum is clean, and freely mounted in the spring assembly.
remove and re instal the image drum..
if that does not work, most likely u need a new image drum,Cyan..i bet it is low and due soon for replacement...
good luck
Posted on Nov 11, 2010
4 Suggested Answers
SOURCE: 133:fatal error
what?
Posted on Jul 22, 2008
  • 78 Answers
SOURCE: SERVICE CALL 188 : FATAL ERROR
Service Call 188: Error: Sub-CPU Communication Error
1- Check the connection of the S2M board.
2- Replace the S2M board.
If the problem does not go away after a reboot you'd better call Oki (it should have a 3 yr. waranty) or an experienced oki technician.
This is not something you should want to fix yourself. The replacement of the s2m board is not an easy task (even for an experienced mechanic)
Posted on Oct 09, 2008
puertobori
  • 7733 Answers
SOURCE: please what can I do
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Posted on Nov 10, 2010
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
Jun 20, 2016 | OKI C Office Equipment & Supplies
That error is an LED detection error. Check the connections for the cyan LED. Also the fuse on the pcb for that LED. If those check out OK than you can try swapping the LED's to see if the error travels with the LED. If the error travels then replace the LED. If the error does not travel then it is more likely the PCB.
Aug 17, 2014 | Oki Electric Industry C711n Led Printer
Im having a Asus psgc -mx/133 board with 1 gb ddr2 and 40 gb bata hard drive ,while open the system it apears coms went worng coms battery worng system halted chassis /fatal error
Firstly your motherboard will not accept DDR2 memory. It will however accept PC133 RAM. Also it won't accept 1Gb and will only work with Windows 95. Although you may be able to get it to run Windows 98. Your board is very old( Antique) get a new one from the recycling center. It will be faster and more useful.
Aug 16, 2013 | Computers & Internet
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
How do i fix a 131 fatal error?
FATAL ERROR 131, 132, 133 OR 134 ON THE DISPLAY ON POWER-UP
CAUSE - ONE OF THE LED PRINT HEADS IS DISCONNECTED
SOLUTION - RECONNECT THE RIBBON CABLE TO THE PRINT HEAD
Just for information, the led print heads are the four assemblies that hang down from the lid of the machine when you open it.
Sometimes they become unclipped, and the ribbon cables can get pulled loose.
131 probably means the front one.
Mar 04, 2011 | Office Equipment & Supplies
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
430 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
