Question about Maytag MSD2656G Side by Side Refrigerator
Maytag SXS Refrigerator
Hi There. I am having a problem with my Maytag SXS Refrigerator. I believe it sounds like a defrost timer/heater problem. (Ex and I owned an appliance repair company for years). The freezer is cooling and yet the refrigerator is not. Found ice in the damper between the freezer and frig and also it leaked water on the floor during the night. What do you think?
Thanks
    Genius:
  • 2,920 Answers
Freon leak?
Posted on Aug 27, 2008
Maytag sxs; freezer frosts up no defrost + runs all the time + fridge side is cold.? Thanks.
Try to turn the defrost timer manually to force into defrost. If the frig defrost the ice then replace defrost timer. If unit dose not defrost the ice then check defrost heater and replace if needed.
Oct 26, 2014 | Refrigerators
Hi, how can i fix maytag refrigerator gt1626bas and it doesn't defrost, ice was all over, I melt it, and I checked the heater,but it's cold, few days ago it stoped working completely but in the back
IS THE TIMER MOVING TO ACTIVATE A DEFROST CYCLE? IF SO THE HEATER MAYBE OPEN CIRCUIT; OR DEFROST SENSOR IS OPEN CIRCUIT EITHER WILL STOP A DEFROST CYCLE HENCE LOADS OF ICE!!!!!
May 11, 2014 | Maytag Refrigerators
Freezer fan keeps running & I have frost buildup
Hello Jerry. Your SXS refrigerator has one of 3 possible problems. 1-the defrost timer is bad. 2-the defrost terminator is bad 3-the defrost heater is bad.
Out of the 3, the most probable is the defrost Terminator, p/n 297216600, $12.00 If this goes bad, and many do, then the refrigerator will not be able to initiate a defrost cycle.
The next likely is the Defrost Timer, p/n 215846602, $ 16.00
To test, using a flat blade screwdriver, located the defrost timer, down on the bottom left side of the refrigerator, and turn the timer until a click is heard. stop turning and check for 120vac on the defrost line at the evaporator. it is either a brown or a pink wire. If you have a non-contact voltage detector, just probe around for voltage. If you have voltage, then you need to replace the defrost terminator. if you have no voltage, replace the defrost timer.
The last possible is the defrost heater. this should ohm out at or around 15k ohms. But in reality, anything other than an open circuit is ok.
Timer, terminator first !
Apr 10, 2014 | Frigidaire FRS20ZSG
Fridge not cooling but freezer is maytag model mtb1553ar
Your MTB1553ARA Refrigerator sounds to me like it is not defrosting properly. Look inside the freezer along the back wall and see if a layer of snow is building from top to bottom. To test if defrost will work open the fresh food compartment and look for a small opening were you can turn the defrost timer slowly clockwise until compressor and fans stop running. Click here=> MTB1553ARA Fresh Food Section Control Panel and in that photo you will see the=> 68233-2 Defrost Timer that has a dial in the center I need you to turn clockwise. After the compressor and fans stop I want you to allow the refrigerator to remain off as it is for 30 minutes. The freezer should now be defrosting and if after thirty minutes the refrigerator does not restart on its own then again turn the timer again slowly until it does restart. If you need to restart the fridge this way then the problem is the 68233-2 Defrost Timer Next I will detail how to install the 61001946 Defrost Heater and the=> 61005254 Defrost Thermostat
if the defrost timer is not the reason for this happening. Here is a MTB1553ARA Parts Manual PDF Let me know here how the defrost timer test goes, Thanks Sea Breeze
Jun 21, 2012 | Maytag Refrigerators
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
Not cooling/freezing good
sounds like a defrost problem. defrost system consists of defrost timer or defrost control board,defrost heater,and defrost thermostat. most maytag sxs refrigerators have a circuit board in charge. part no.61005988 adc board.change the board and yer in business...
Frig Freezing Up/Frig side warming up Maytag MSD2454GRW
I think your voltage is fine I just believe the defrost timer is worn out and not cycling properly resulting in less defrost and higher refrigerator temperatures. Thanks, sea Breeze
Aug 26, 2009 | Maytag MSD2454G Side by Side Refrigerator
GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Maytag MSD2656G Side by Side Refrigerator Logo
208 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
