I remove the cmos batt. reinstall now my computer tells me that there is no bios values and I should enter it. I don't know what to do.
  • 1,179 Answers
Enter the BIOS and select the item for Load optimal defaults or factory defaults, remember to set the date and time. You may also have to auto detect the hard drives by selecting the auto detect hard drives.
Posted on Nov 10, 2010
Reset cmos
Modern computers use a BIOS not CMOS. Regardless of what we call it, if you can enter the BIOS by pressing the F2 key (could be a different key, check manual) there should be a choice to restore defaults. If you cannot get into the BIOS then usually just removing the small silver coin battery from the motherboard for 10-seconds and reinstalling it will reset the BIOS and your clock (which is how you will know it has been reset.)
If you are trying to reset the system because of a lost BIOS/Low Level password, take note that these passwords are often stored in a special microchip on the motherboard and often require a new logic board be installed to resolve the issue. Manufacturers protect the BIOS passwords to help protect user information and to reduce the value of stolen computers.
Jan 04, 2014 | Toshiba Satellite L840-BT2N22 Customizable...
Cmos checksum error-defaults loaded
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program.
This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty.
It could also be another component on the motherboard.
Make sure the battery has plenty charge or remove the battery for a while, about 5 minutes to see if that restores it some motherboards cmos batteries are soldered in
You could check the site for the machine vendor to see if there is a reset jumper.
If that doesn't work then you will need to refresh the BIOS
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS.
To do that you need to press a key while the computer is booting Usually the Delete or F2 but can be other keys
It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one.
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Press F10 Save, Exit and re-boot and everything should then work
hope this helps
Aug 03, 2012 | Dell Computers & Internet
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
CMOS error
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent hardware or software change
If you don't know the settings you should be one for optimal defaults - use that one. You will also need to reset the time and date.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Dec 07, 2011 | Intel Desktop Board DH61WW Classic Series...
Bad check sum cmos
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Foxconn n1996 chip needs replacing as had power cut as updating bios
Reboot the computer.
If error still occurs after rebooting the computer enter CMOS setup and check all values, this includes verifying the time and date are correct.
Once everything has been verified and changed make sure you save and exit CMOS setup.
If everything appears to be correct and the issue persists try resetting the CMOS values to the defaults or Reset Configuration Data.
If this issue continues to occur after you turn off your computer off it is possible that the CMOS battery may be failing or already bad. Before considering replacing the CMOS battery try leaving your computer on for several days.
If a BIOS update has been run on the computer the values stored in CMOS may have been reset. Enter CMOS setup re-enter all values and then save and exit CMOS setup.
If you're unable to enter the CMOS setup or after running a BIOS update your computer no longer keeps its values the incorrect BIOS update may have been installed for your computer or the version downloaded may be corrupt. We suggest trying to update the BIOS again or reverting back to an earlier version.
Hope it helps
Nov 09, 2011 | Dell Studio Xps 9100 Desktop Computer
How to fix,when power on my pc i always see htis bad bios checksum
Jul 20, 2011 | ASUS P5KPL-AM SE Motherboard
The CMOS setup has gotten corrupted. This may have happened if the 3 Volt coin battery on the motherboard is low. If your date and time is wrong, that is a clue the battery needs to be replaced.
If you have a voltmeter, check the voltage on the coin battery. It should be 3V. If it's much less that that, it must be replaced.
Whether or not the battery is bad, you will still have to enter SETUP when you boot the computer after replacing the battery. At boot, it usually displays what key to press to enter setup (DELETE, F2, etc. )
There are several menu screens which you must ensure are correct, according to the hardware installed on your computer.
If this is too daunting, take it to a computer repair place, and they can do it for you.
Jul 13, 2011 | Compaq Computers & Internet
My MOBO is ASUS P4VP-MX. My bios fails to start. I reset my pins for bios the computer will run but when I restart again it will gave message that that BIO checksum failed. Is this a battery failure. I...
This error is not the same as a cmos Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Jul 02, 2011 | Intel ASUS X Series Motherboard P4VP-MX...
Cmos checksum bad
hope this helps
don't forget to vote
Feb 11, 2011 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
