Back to:
Tags:
VCRs
Generic problem for all VCRs
Vcr Samsumg Vr8460
posted by Sedrick75 on Jun 17, 2008
The VCR dont record only in the timer recording function, other function are fine play and rec manually, Can you help me?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 17, 2008
Not Rated (0)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 264 votes
1. Is the VCR coming on in the timed mode and recording? Make an experiment- set up a timed record for just a few minutes in advance. Have a tape in the machine- then wait a few minutes & see if it indeed comes on and records. This should for sure help you diagnose your problem.
Note: When a timed record is set up, some VCRs must be turned off, or a particular button pushed to activate the timed record mode, where it will wait for the specified time and come on by itself..
2. Video source set correctly? If all you get is a blue screen, or a moment of snow, then the timed recording is happening, but there is no signal present.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Vcr Samsumg Vr8460:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
recorded a programme of t.v, on playback got the right...
VCRs
What is mdel code for VCR EWV404?
VCRs
I can't figure out how to tape a tv show on the vcr mode,...
VCRs
Trying to engage VCR to TV [Audio logic P1430] without...
VCRs
I have a hitachi video recorder vt-rm800ev and i need a...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
