Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sorry if this posts twice. I think I might have posted an ealier question in an improper area. I have a Sony Wega 32" Trinitron Model KV-32F S200 (Year 2003) Recently, I've been getting a Green tint on the picture and also green lines Horizontally. I am also starting to get thin Green lines that overlap the Horizontal lines that are gradually moving from a Horizontal postion toward a Vertical position. Are there any ideas out there on what could possibly give me some kind of clue on what is causing this?
    Top Expert:
  • Sony Master
  • 74,383 Answers
Hello
There are two causes for this problem. One is related with green output transistor, and the other is to chroma Ic. The most common cause is with the transistor said above. You just check the video output voltage points at picture tube base board. There are three cathodes may be marked as R,Gand B. In trinitron picture tubes, these pins are pin number [8 Blue KB], pin number [9 Green KG] and pin number [10 Red KR]; and the voltages must come approximately equal to KR=154, KB=155, and KG=163, and the main video output voltage goes to these transistors will come around 225VDC. These are not accurate voltages tor refer. It may vary by 2% to set by set. All the three transistors used will be identical in number, and usually found 2SC3271N. In your TVs case, green cathode voltage may be very low from the fault stated above I thinks. When cathode voltages goes low, emission of that cathode will increases, and colour of that cathode will be predominent. You just check these voltages, and check the main video input voltage said above too. There are three resistors of 2W fitted to the the main video voltage and collector of each transistor said above; and if any one,say the resistor fitted to green output transistor collector is faulty, or open or loose sodered, the voltage at the green cathode [pin-9] will be low causing this problem. If the transistor said above gor a leak with collector to emitter will also may the cause.
Just check it. Normally this base card of Sony TVs are marked C board. If all the transisors are found okl, and still the problem perisits, the fault must be in the Chroma Ic. It may need replacement.
In practice,I found this fault to be due to bad solderings in the base card. You just check it first and go forward.
If any doubts, contact me through Fixya. OK.
Posted on Nov 10, 2010
Testimonial: "I thank you very much for your input..I will use this expert advise in correcting the problem that I'm experiencing."
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Removing sony trinitron back
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Disassemble procedure to many model Sony TVs are described in detail with illustrations.
Apr 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-32F BLINKING 3 TIMES
KV32FS120 or 32FV120 etc as codes vary by model number.
Apr 10, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i take my sony wega trinitron off stand by
Generally speaking, when the set stays in standbny with the light blinking, there is a problem internally that is detected and the set remains off to prevent further damage. The standby light shouldb e blinking in a repeated pattern of X blinks. Please post the model number (KV-32FS120?) and the blink count and I will be able to provide more details about the problem and its resolution.
Thanks,
Dan
Dec 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony FD Trinitron Wega degasses and goes to standby, blinking 6 times. Worth reparing this almost seven yr old set?
Rather get a quote first , then you can decide whether you need a new set or not ?
After SONY sets work like dogs especially if you use them alot. Think about a replacement cost ?
I would say get a quote before you decide.
May 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv will not turn on
the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
powersupply rectifier diodes, power trasistor lekage,
diodes, zener diodes,
if a 90-110 volts to the line trasistor,
a line transistor be checked.
the tv simple problem
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony kv-32fs120
The 6 blinks mean no horizontal. Check the horizontal circuitry. I'll look up your specific model later and post more details.
Dan
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
416 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
