Question about Dell XPS M1210 Notebook
Hi I have Dell XPS M1210 laptop. When I turn on the screen nblinks for a second and then goes real dark. at first it look like its gone blank but if you look closly, the screen is on but very dark. I changed the battery but didnt work.Can some one help me? thanx.
  • Dell Master
  • 5,660 Answers
Farooq473, replace the Inverter.
1) An LCD screen cannot produce enough light by itself. A Backlight is used to help provide the needed light.
2) An Inverter is used to provide power for the LCD screen, and the Backlight.
An Inverter boosts power up for the LCD screen, and lowers it for the Backlight.
90 percent of the time a bad Inverter is the problem.
A Backlight usually goes out all at once, Inverters slowly 'die'.
Dell Support > XPS 1210 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/xpsM1210/en/SM/index.htm
In the list click on > Display
Now click on Display Panel.
Dell doesn't show, and describe how to replace the Inverter.
When you click on Display Panel, you are looking at an exploded photo showing the Display Panel removed.
Scroll down to the next small illustration.
Has 1, 2, 3, 4, and 5 pointing to the Display Panel.
5 shows you a pull tab to release a flat cable from the Inverter. The Inverter is the small circuit board to the left of the pull tab.
This is not advertising for this website. Just an example to show you what the Inverter circuit board looks like.
(Screen Inverter)
http://www.battery-adapter.com/product_info.php/products_id/3450
This is Not a Dell XPS 1210 Notebook PC. It is a guide for replacing an Inverter in a Dell Inspiron 1525 Notebook PC, but I wanted you to have photos, and instructions for the basic procedure.
After you have repaired over 100 laptops, you'll realize that they all have the same basic procedures.
Just different parts.
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
3) Be SURE ALL power is removed from the laptop before you start.
Remove the AC adapter (Charger) and Battery.
4) You should follow Anti-Static Precautions implicitly. It would be best if you bought, and wore an ESD wrist strap. (Electro Static Discharge) Connect the alligator clip to a good ground source.
(For example, I connect to the metal frame of an empty desktop computer case)
The cost averages from $3 to $12.
A $3 ESD wrist strap will do just fine.
This is an example of an ESD wrist strap,
http://www.amazon.com/Cables-Unlimited-ACC-1400-Static-Grounding/dp/B000EDMPQK
5) Use a multi-compartment container for the various screws you will remove.
Label each container for the area the screws came out of.
You DO NOT want to mix them up!
You can use a clean egg carton in a pinch. Label each egg holder.
Have questions post in a Comment.
Regards joecoolvette
Posted on Nov 10, 2010
  • 1 more comment
  • joecoolvette
    joecoolvette Nov 11, 2010
    Appreciate the rating farooq473, Most Kind!
  • Muhammad Farooq Nov 22, 2010
    Hi .. Thanx for the help...i tried that and it worked for few hours but then screen goes out again, so I ordered another Inverter but didnt work...I guess there is something that keep killing the inverter...Do you have any idea what it is/ Appreciate the help again.
    farooq
  • joecoolvette
    joecoolvette Nov 22, 2010
    farooq473, do you have a VGA monitor available?
    If so I would like you to plug it into the VGA connector on the back of the laptop.
    Turn the VGA monitor on. Now turn the laptop on.
    Press the Fn key, and hold it down, then tap the F8 key.
    This will toggle your display from the LCD screen of the laptop over to the VGA monitor. Need to see if there's a problem with the Nvidia GeForce Go7400 graphics chipset.
    It may be similar to a problem that occurs on HP Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's.
    To wit;
    http://www.youtube.com/watch?v=bnkQNmKau...
    (Just to add. I would use a Heat Gun, instead of a Propane torch)
Dell XPS M1210 Stuck on blue screen due to hard drive
To determine if your hard drive is bad or good, run the Dell diagnostics.
Here is a link for the owner's manual of your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1210_owner%27s%20manual_en-us.pdf
Feb 08, 2013 | Dell XPS M1210 Notebook
Dell xps laptop lcd screen black
If you have an external monitor, try connecting the laptop to it, then toggle FN+F8 to project display from lalaptop to external monitor.
If the external monitor does not have a display aswell (totally blank) , then its a problem with the video card.
You can also run an LCD Bist test by turning off the system , then while the system is turned off press D + power , If you dont hear a beep but no display at all, then its an LCD problem.
Hope this helps
Thanks
Dennis
Oct 18, 2011 | Dell XPS M1210 Notebook
How can i change the cmos battery of dell XPS M1210 laptop?? how to open the case of dell XPS M1210 laptop???
akip all the screews then cover down open here in rigth side see the batery disconect it for a few seconds and then put ir again and ready some times only with the tap of the memory can see it battery remplace it too
Jan 07, 2011 | Dell XPS M1210 Notebook
I was watching a video in my Dell XPS M1210 when it suddenly stopped and the screen when blank. I unplugged it and tried to switch on but I still get a blank screen but the power button has lights as well...
The inverter or backlight on the display may have gone out. Connect an external VGA monitor to the laptop. If it works, then the display has a bad inverter or the backlight CCFL lamp went out.
Nov 12, 2010 | Dell XPS M1210 Notebook
Screen on dell m1210 is dark and not readable
Your screen's fabric wiring got internal problem and you need to replace it with new set of socket wires.
Dec 09, 2008 | Dell XPS M1210 Notebook
Dell XPS M1210 Notebook Logo
395 people viewed this question
Alun Cox
