Question about Metrologic Instruments Metrologic MS1690 Focus Barcode Scanner - P/N MK1690-61B14/MABS Barcode Scanner
I'm using usb cable + connect to barcode reader ms1690.. the hardware not found.. cannot detect using the usb cable provided..
Tip
How to connect a barcode scanner to your computer
<p>If you run a business, you probably need a barcode scanner to help control the items in and out of your iTunes. It is also possible to bar code reader to a computer at home. These devices connect through a USB port like most other external hardware. <br /> <p><br /> <p>1. Connect the barcode scanner to your computer via the USB port. A window showing the computer has detected a new piece of hardware. <br /> <p><br /> <p>2. Insert the CD driver installation. Wait until the installation wizard. <br /> <p><br /> <p>3. Follow the instructions to complete the installation. Remove the driver CD and replace it with a software CD is provided. <br />
on Jun 26, 2011 | Computers & Internet
My computer cannot find a Driver for SVP EB701 eBook Reader
Like many other e-readers, the SVP EB701 is a multipurpose device and it can be connected to the PC through USB 2.0 Interface. All you have to do is to connect the e-reader to the PC via provided USB Cable. The PC detects the e-reader automatically. You can connect your e-reader to your personal computer using the provided USB cable. It uses USB 2.0. Connecting your e-reader to your personal computer puts your it in USB drive mode (just like USB Flash Disk). This lets you add files and backup etc. When your e-reader has connected to USB, your personal computer should detect it:
On a PC running Microsoft Windows, you are presented with a choice that includes Open folder to view files or you can browse from My Computer to access the memory of the e-reader.
If you are experiencing issues with it, make sure that the cable is connected properly and the USB port of the PC is working. You may check the e-reader on some other PC as well.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 28, 2011 | Computers & Internet
We have purchased a large quantity of Metrologic Barcode scanners for several years. Most of the models are the rs232 to keyboard type with the Softcom application. While upgrading systems to Windows 7, we...
There should be a compatibility mode which will allow you to run this software. Right click the application shortcut and you should find a compatibility mode in one of the tabs there.
Mar 30, 2011 | Metrologic Instruments HoneywellMetrologic...
I have connected my 4Gb Usb Device to my PC, But
insert the usb drive
if a notification bubble appears click it
a dialog box appears showing the new hardware found
click on the detect automatically button.
it starts searching..
if the driver is in r system it installs
if not download the driver from net
write the device model number and company
check ur usb port......
try using in ur friends computer
Mar 11, 2010 | HHP ImageTeam 4710 Barcode Scanner
I want Modem Driver for HTC Hero phone using sprint network
Using the HTC Hero as a USB Modem
In order to use this functionality, the HTC Sync software must be installed onto the PC first (http://blog.brightpointuk.co.uk/synchronise-htc-hero-microsoft-outlook).
The HTC Sync installer is included on the SD card that comes in the Hero sales package, or alternatively is available for download from our FTP site:
ftp://ftpaccess:Brightpoint1@ftp.brightpointuk.co.uk/Technical%20Support...
You can download the software to your PC, or insert the microSD card into a suitable reader to access the software.
Once installed, on the Hero device browse to Settings --> Wireless Controls and enable the option to enable Mobile Network Sharing. Now connect the Hero to the PC via the supplied USB cable. Windows will detect the new hardware automatically and install an "HTC Remote NDIS Network Adapter": Provided that your Hero has a cellular data connection, you will now be able to use that connection from your PC.
(If you found this information helpful please rate this answer with a big thumbs up and thank you for visiting Fixya!)
Jan 27, 2010 | HTC Cell Phones
Trying to setup a weleh allyn 5700/A-02 barcode scanner fore a usb interface. The user?s guide has no configuration fore this interface. However I have seen them used on a usb interface.
To use this device ave it's own freeware software provided to install such devices or hardware to run into your Computer. Checking your is in good condition or it's factory defect. USB Device such scanner automatically detected when connected to Computer.
Sep 30, 2009 | Computers & Internet
Problem with datalogic magellan 1000i barcode reader
hi
the cable is USB?
if you have usb cable, you read the manual paper "default".
if you have cable rs232 you must install on a PC emulator "softwedge". Open icons and set a comm. Prefer you answer. bye Roberto
May 16, 2008 | Datalogic Magellan 1000i Hands Free...
Not scanning 2D
hello Having loaded the reader to metroset, print setting on paper and you read on paper. This player does not confugura with usb. give me answer. Roberto
Apr 07, 2008 | Metrologic Instruments MS1690 Handheld
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
Metrologic Instruments Metrologic MS1690 Focus Barcode Scanner - P/N MK1690-61B14/MABS Barcode Scanner Logo
52 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
