Our LG fully automatic, front loading washing machine( model WD-1205 CI) stopped working on 3rd Oct 2010.The LG technician told us that the main motor of the machine got spoilt.After a waiting period of 36 days we were told that the motor is not available with the company.The machine was purchased in 2003.I want to know for how long is the company supposed to make parts available for customers. Also if there is any way to procure the motor and repair the machine.
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: Electrolux EW 1005f washing machine trouble.
The number 39404040 is the only one listed on their website.
If it is down because of local problems - I cannot be certain.
Electrolux India has very carefully hidden its service center number on its website. The only option you have is to drill-down to the local customer service center. Unfortunately the number given for Ms. Millenium Service Center for South Kolkata (033-24573470 / 24451120 ) doesn't work. I had to hunt down a certain executive to finally find the real phone number for booking complaint across India.
The Eletrolux India customer service number is (they have listed) 39404040.
Keep your model number, date of purchase and shop dealer name handy while making your call.
The customer service for Electrolux in India is suspect to say the least. CLICK HERE For a number of service centers in a few locations (you will need to read through the posts to determine the cities and corresponding #s called by posters.)
However after reading the posts - Your best option may be to have the part mailed to you from a different country!!
The toll-free number in the us is - 877-435-3287.
CLICK HERE to eMail Electrolux.
They will be able to direct you to a service center in India, or get you the parts you require.
Thanks for using FixYa!!
If you need further assistance please contact me again first.
Posted on Mar 31, 2009
  • 574 Answers
SOURCE: Much needed parts for ES-550F Fully Automatic Washing Machine
you could try partselect.com hope this helps.
Posted on Sep 16, 2009
Kuwagata
  • 181 Answers
SOURCE: I HAVE WD-10165F LG WASHING MACHINE, BUT ITS DRUM IS NOT WORKING
Possibly the Main Capacitor is leaked/ burned.Try replacing it with new ones.
To locate it, you can follow the schematics diagram behind the machine.
It's look's like a mini can with cable, sometimes the color is white, and on the body written 25uF/400 VAC, or something like that.
Hope this work, if still won't, contact me for furthure assistant.
Posted on Oct 23, 2009
ginko
  • 19396 Answers
SOURCE: when pulling out heavy load
Hi.
I uploaded the full service manual at the link below. The schematic views are in the last pages of the manual.
Try first:Click here to start download..
If that does not work, proceed from: WD-1049C Service Manual
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 09, 2010
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
WD 1205 CI Washing Machine
Please check on this link for spares: Parts
Jan 18, 2013 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
We bought LG front load washing machine LDP series in Oct,2010. Now sound got increased when it is washing and water is also leaking. COuld you please help .. in how to fix them.
sounds like the bearings are gone massive job almost complete rebuild call lg straight away and have it repaired or replaced while it is still under warranty
Jan 11, 2011 | LG WM-2277HW Front Load Washer
Main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
May 30, 2010 | LG WD-16115FD Front Load Washer
I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are...
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
May 21, 2010 | Washing Machines
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Jan 06, 2008 | LG WD-16115FD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
