Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
PT-45LC12 45 is this the white looking small cylinder looning thing on top with the black wire coming to it?
  • 3 Answers
cut it and jump the wires.
Posted on Jun 17, 2008
Treadmill is stuck in incline postion and can not put down. screen says error
Unplug the treadmill. Remove motor cover . Look for the incline motor, follow the wires coming from the incline motor to the controll board. Starting from the top you will see a red,white and black wire. Under those wires you will see a white and black ( do not remove the lower white and black). Remove the red wire and the black wire . Swap the positions. Plug the treadmill back in and turn with the safty key in place.. The treadmill should go back down. Once it's down . Remove all 3 incline motor wires from the controller. This will get it back down so you can use it. It will still give you the incline err , just press stop to bypass it. As for what is causing the problem , a number of thing can cause this problem. I would call sole and ask for a tech in your area unless you're in NC you could call us. Good luck
Jan 08, 2015 | Sole Fitness F63 Treadmill
Camaro Resistor keys, Starting problems.
I fixed my 99 Z28 myself with a 20 cent resistor. Dont let GM fool you into buying a new ignition cylinder or even a new key. If your camaro has a Resistor key at one point most likely before 100,000 miles your gonna turn your key and your security light on your dash is going to flash2_bing.gif constantly and your car wont start. If you want a quick fix without all the hassle of changing the ignition cylinder and buying a new key that cost over 100 dollars parts only, labor to install much more, just take a ohm meter measure the ohms on your key. The little black chip at back of key has a metal piece on each side place meter probs on each side, look at ohms. Now go out to radio shack or an electronic wholesale place and buy that ohm resistor you may have to combine some to make the ohms it doesnt have to be exact within 15 ohms is fine. Now remove 4 screws holding bottom plastic cover under dash just below steering column, carefull of trunk release connector. Find a small 2 wire with black connector and a orange sleeve coming from steering column that covers wires almost down to connector, both wires are mostly white and very small, solder the resister across these 2 wires, heat shrink resistor or electrical tape. Bingo your car starts! And you never have to worry about this defect in the ignition cylinder again. If you still want the security feature just put a push button on the resistor across the wires and hide button under the dash. Trust me the new ignition cylinder will do the same thing again in the future, was a bad design on GM on this cylinder, wires move with ignition cylinder and eventually break. Hope this helps and saves money for you Camaro Fans!
on Jun 02, 2010 | Chevrolet Camaro Cars & Trucks
I have a used ceiling fan that I want to install. I see only three wires coming out of the top; a black, a white, and a blue. The fixture has the fan and 4 lights attached. Can you tell me how to...
Black is the hot wire, white is the neutral, and blue is the hot wire for the lights. If you only have a black, white and green(ground) coming from the electric box in the ceiling, you will have to wire the blue and black together coming from the fan and connect them both to the black coming from the box. The white will connect to the white coming from the box in the ceiling. You should have a ground wire off of the fan. If not look for a ground screw on the fan down rod. The ground is for safety.
Apr 08, 2011 | Heating & Cooling
Foodsaver pro locked up. 3 green lites blink off and on. is the problem fixable?
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
Oct 17, 2010 | Tilia FoodSaver V2240
Electrical hookup
Tie all the black wires together and connect to the black power wire coming from the switch. Tie all the white wires together and connect to the white wire coming from the switch. If this does not work then what you have is a switch leg going to the light. This will be just a white and black wire coming from the switch with another power wire going in. Look at the switch and see if you have a white and black wire connected to the 2 screws. if so this is a switch leg. You will have to disconnect all the black wires in the light mount and find which one is carrying power in. Let me know what you find and we will proceed.
May 23, 2010 | Home
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Need coil wiring diagram
Contact points cover open.
Left side points are for cylinders 1 and 4.
Right side points are for cylinders 2 and 3
Left side points have a White wire coming from it.
Right side points have a Black wire coming from it.
One coil runs two cylinders.
One coil runs cylinders 1 and 4.
One coil runs cylinders 2 and 3.
No matter what style of ignition coil you use, the Black wire will connect to the Points. Whatever other color of wire they use, connects to the ignition switch.
BUT, check the specifications for the coils you're going to install. Connect the Negative side to the points. The Positive side to the ignition switch.
The Orange wire with a White stripe, coming out of the harness of the Suzuki Gs550 is from the ignition switch. It goes to a splice connector, and from there goes to two wires. The wires split off into one wire for each coil.
There is a White wire on the coil, that is used for Cylinders 1 and 4.
There is a Black wire on the coil, that is used for Cylinders 2 and 3.
Oct 21, 2009 | 1979 Suzuki Gs 550 L
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
I need to know witch plug wire goes where and the color of wire goes on top and bottom of the coils
Hi and welcome to FixYa,
To my understanding, for an 89-92 US/UK GSX750F:
  • left ignition coil supplies cylinders 1 & 4;
  • top terminal is white;
  • bottom is red/white;
  • right ignition coil supplies cylinders 2 & 3;
  • top terminal is black/yellow;
  • bottom is red/white.
Good luck and thank you for using FixYa.
May 15, 2009 | 1992 Suzuki GSX 750 F (Katana)
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
