Question about Cell Phones
When trying to install mxit on my blackberry, it says Connection failure. Error-11. And when I select Help, it says Your country specific settings are currently not available. Please contact your network service provider for more information. And when I try to change country, United Kingdom is my only option. I stay in South-Africa.
rush2robby
  • 83 Answers
SOURCE: unlock nokia 7373
ok try following steps:reboot your phone when they getting reboot press = green button(answer key) + 3 star key(*) but befor that make sure that your phone data will be lost above procudere may restore factory settings of your phone
Posted on Oct 25, 2008
SOURCE: Mxit Problem
Bagaimana caranya menghapus semua settingan GPRS di hp V3
Dari belinya sdh ada settinganya
Dari kapasitas settingan terbatas
Saya mau rubah yg gak di perlukan
Terima kash banyak boooss,,,,!!!?
Posted on Jan 02, 2009
VinayT
  • 1884 Answers
SOURCE: I am trying to setup my wap settings for internet
Basically what you need are IP address - ask MTN. Proxy Port setting enabled/disabled. Ask MTN. Proxy Port number. Ask MTN. APN. Ask MTN. All these are service provider specific and hence I have asked you to ask MTN. Other settings can be anything. Also you have to get GPRS activated on your mobile number. Ask MTN again. When you have all this inf, then set it up and happy surfing.
Posted on Nov 21, 2009
MXit_Team
SOURCE: hi, how do i reset my pin, used mxit in south
When you download MXit, you will have to change your location/locale to South Africa before logging in.
Posted on Dec 03, 2009
SOURCE: I bought a chinese mobile 8310 blackberry phone
you just have to manually input the gprs settings on your mobile 8310 phone. copy the settings of other net-capable phones. we have the same phone, and i'm happily surfing the internet... :)
Posted on May 08, 2010
I want to use my blackberry 8520 as modem to my laptop
Yes. I used to do that before 3G became popular.
The Dial Code depends on the country and carrier. I used *666#
Set Up a Dial-up Connection
You'll need to set up a dial-up connection on your Windows machine to use the BlackBerry modem. When you installed the BlackBerry Desktop Manager, it should have automatically installed the modem drivers to use with your device, and you should have a modem called "Standard Modem" in the Phone andModem Options section of your Control Panel. The drivers are located in the following folder: C:\Program Files\Common Files\Research In Motion\Modem Drivers. Use the following steps to set up your connection:
  1. Connect your BlackBerry to your computer using the standard USB cable that came with your device and start the BlackBerry Desktop Manager software.
  2. Go to the Control Panel, then Network Connections, and select Create a New Connection.
  3. Select Connect to the Internet, then Set up my connection manually, then Connect using a dial-up modem, and select your BlackBerry modem from the device list.
  4. Choose a descriptive name for the ISP Name (e.g., BlackBerry Modem Connection).
  5. Enter the phone number for your service provider. You'll probably have to check with your carrier to get the right number. For Cingular and other GSM carriers (AT&T, T-Mobile), it's *99#. For CDMA providers (Sprint, Verizon), the number will be #777.
  6. The username and password will vary by carrier as well. Cingular just accepts null values for both fields.
  7. Complete the wizard, being sure to deselect the "Make this the default connection" checkbox.
How to use Blackberry Curve phone as modem O2 Guru TV
Jul 16, 2016 | RIM BlackBerry Curve 8520 Smartphone
Cant download mxit
Before you do anything, you will need to download yourself a copy of Mpowerplayer, which is a java virtual machine. Mpowerplayer will allow you to mount a java file and run MXit. You can get Mpowerplayer by clicking here.
Once you have download and installed Mpowerplayer, you will need to get yourself a copy of MXit. You can do this by clicking here firstly, this will take you to the MXit WAP site. Follow the sets below to get yourself MXit:
1. Choose your language.
2. Click on 'Choose phone'.
3. Select your phone make and click accept.
4. Select your phone model and click accept.
5. Select your country and click accept.
6. Select your region, and type in the image code.
7. Click on the 'Normal' link.
This will now download a .jad file to your computer. Make sure you choose a good place to download it to, so you can easily find it once it's downloaded. Once the file is downloaded, which should only take a few seconds, launch Mpowerplayer.
Once Mpowerplayer is open, click on File at the top left of the program, and select 'Open..'. Locate the .jad file you downloaded and open it. This will load MXit in the Java Emulater (Mpowerplayer). From this point on, everything is exactly the same!
Have fun using MXit on your computer!
Jun 07, 2011 | Computers & Internet
I've installed mxit on my blackberry 8520 and it says error code 11 and then it said please select 'help' and so I did. i followed the instructions and did what they said but yhen when i try again it says...
You need to install blackberry ota downloader straight to your phone ,it won't open but just save it.Mxit will work then.This only works for Mtn I've done it with the 8520 and 9700 and it works perfectly without Bis or the monthy blacberry data bundle.Won't work with vodacom however hard I tried
Feb 02, 2011 | Cell Phones
Have a Chinese smart phone and need the detail setup for gprs rogers communication
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to goam.com (lowercase), if not work, try "internet.com"
8.Edit Username to wapuser1
9.Edit Password to wap
10.Edit Auth Type to Normal
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://mymobilehomepage.rogers.com
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 208.200.067.150 and the port number is 80
10.Edit Username to wapuser1
11.Edit Password to wap
Select back or done
Select Activate Account
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mms.gprs.rogers.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 172.025.000.107 and the port is 80
Edit the Username to media.com
Edit the Password to mda01
Select Done or Save
Make sure to activate the profile and you are good.
Restart the phone.
COUNTRY: Canada
CARRIER: Rogers
Internet Settings
APN: internet.com
USER: wapuser1
PASSWORD: wap
HOMEPAGE: http://mymobilehomepage.rogers.com
PROXY: 172.025.000.107
PORT: 80
MMS
APN: media.com
USER: media
PASSWORD: mda01
HOMEPAGE: http://mms.gprs.rogers.com
PORT: 9203
Mar 01, 2010 | RIM BlackBerry Curve 8310 Smartphone
I'm trying to log in mxit and it keeps on saying 'connection error please check your GPRS or try again later' could u please help
my mxit says 'connection error please check your GPRS or try again later' could u please help.What must i do?.
Feb 24, 2010 | Samsung SGH-E370 Cellular Phone
Is mixit posible on a blackberry 8520
Hey a can download my mxit but when a whant to open it says erre 11 I am celc pleas help
Jan 29, 2010 | RIM BlackBerry Curve 8520 Smartphone
Installing Sprint Smartview on Windows Vista --Dell laptop
Smartview is supposed to work with Vista. Did you right-click on the install file and run as administrator?
If you can not get it to work there is a work around.
First, download and install the BlackBerry Desktop Manager software. After installation, plug in your BlackBerry and start up the software for the first time. Open the Options -> Connection Settings… window and set the connection to USB. Plug in the BlackBerry, enter your password if applicable, and Vista will find the device and install a “standard modem”.
Open the Control Panel
Network and Internet
Connect to a network
Set up a connection or network
Set up a dial-up connection
Select Standard Modem
Dial-up phone number is #777
Connect.
Everything should work, some have reported faster speeds using this method over the Smartview program.
Mar 13, 2009 | Computers & Internet
Blackberry error 513
my phone creen say error 513 my usb dont ddeteck the bb i don no please help me tansk
Sep 04, 2008 | RIM BlackBerry Pearl 8100
Mxit Problem
i downloaded mxit, set the GPRS several times but still cannot loggin on mxit
Dec 22, 2007 | Motorola Mobility V360 Cellular Phone
Mxit Problem
Oct 09, 2007 | Cell Phones
Cell Phones Logo
448 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
