Power supliy resistant missing - Televison & Video
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
You can replace it with the Resistor 2Ohm-19Ohm 5watt - 20 Watt.
Posted on Nov 10, 2010
Heater fan not working on my 2003 cavalier
From your symptoms I would suggest, inspect the Climate Control and the Blower Motor Resister. Locate and remove the resister and test. You are looking for power at the plug (going to the resister). One wire will always be hot (with the ignition key on). The other four wires are ground wires that through the resister, changes the blowers speed. Connect a test-light to 12volts positive, test that the test-light is working, and then start testing for ground. Unplug the resister and test at the plug. With the ignition key on, test each wire. Each wire should light up your test-light depending on the position of the speed control knob. If it passes then plug the resister back in and probe at the blower motor. The blower motor needs both ground and power to run. Find out which is missing and write back. Good luck.
Apr 26, 2014 | 2003 Chevrolet Cavalier
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
1993 Villager: My van has poor take off power .and it misses on t...
clean the MAF sensor resister wires with carb cleaner carefully. The Maf is in the air intake tube between air filter housing and throttle body.
May 16, 2010 | 1993 Mercury Villager
Miss fires
hi
check the following
1) Coils (check its resistance and compare it eith the required one in ur manual)
2) Coil Electrical wiring (may be it's corroded, u must check its resistance (check continuty))
3) check if the problem from Ignition computer (ECU)
Aug 20, 2009 | 2004 Mercedes-Benz C-Class
Glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Apr 12, 2009 | Plumbing
Miss fire in cylinder #1, 1998 subaru legacy outback
fuel injectors getting ground from pcm?
Oct 29, 2008 | 1998 Subaru Legacy
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
