Question about Nikon D200 Body Only Digital Camera
When I put a card inside my camera D200, the massage displays and blinking "For", whats the issue and how can i fix it
    Genius:
  • 1,177 Answers
Sounds like a format error. Try formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Posted on Nov 10, 2010
My Nikon D2oo is not working with Extreme 111 Compact flash cards that I just had the camera Format. There is an burn oder coming from either the camera or card.Wanting to put card not formatted with...
Hello, and thanks for using FixYa.
Please if the card contains any important pictures, connect it to a computer and copy them to the computer if they are not backed up. Then put the card in the camera and format the card in the camera, then you can connect it back to the computer, put those pictures in there and then the card back into the camera if that is what you wanted to do.
Note that the camera might not show your pictures, unless they are named the same way as original pictures taken with the camera.
Oct 22, 2010 | Nikon D200 Body Only Digital Camera
My Nikon D200 refused to turn on!
Afraid bad news is correct, it sounds like main control board.... You will need to get a quote from your local Nikon Service Agent..... Good Luck
Aug 29, 2009 | Nikon D200 Body Only Digital Camera
Nikon d200 sprayed with water
I would suggest that you give the contacts a good clean (gently of course) on both the camera body and lens'.
Also although the water would make no difference, make sure if you have any lens' with aperture rings to put them round to F33 or the smallest aperture, if they aren't this will cause the fEE.
Hope this helps
Drew
Oct 06, 2008 | Nikon D200 Body Only Digital Camera
Can not format card for Nikon d200
Is you camera plugged into you computer. If so, you cannot format the card from the camera, unless it is unplugged. This just happened to me (I was about to look for a bent pin). Unplugging solved the problem.
Sep 26, 2008 | Nikon D200 Body Only Digital Camera
D200
what is the actual proablem?
Nov 17, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 and microdrive
I assume by "microdrive" you mean the compact flash card - right? Not all compact flash cards will word with the D200 - what is the brand of each of the flash cards you have (and are they all the same-purchased at the same time)?
Nov 02, 2007 | Nikon D200 Digital Camera with 18-200mm...
Exposure button not working
Have you done the firmware update? If not the update is available here: CLICK HERE FOR MACINTOSH or CLICK HERE FOR PC.
If that didn't solve your issue, you may have to go to an authorized Nikon dealer to have the camera reset. The internal battery cannot be serviced by untrained persons. I would also suggest that going forward, you carry your camera inside your coat when you're outside in cold weather, since electronics are easily damaged (especially software) by frost and / or water vapor which can very easily damage parts of your camera (hardware and software) in any weather.
Oct 20, 2007 | Nikon D200 Body Only Digital Camera
Nikon D200 Body Only Digital Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
