Question about Olympus FE-230 Digital Camera
The memory card of my camera is write protected and i cannot format it
  • 320 Answers
Remove your memory card from the camera and set the tiny switch to unlock position. The switch is located at the side of the memory card.
Posted on Nov 10, 2010
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I have a V1003. It is saying memory card is protected (reset switch on memory card).
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card (which you said you've tried), or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 30, 2011 | Kodak EasyShare V1003 Digital Camera
My camera is showing 'memory card is protected' ?how can i solve this problem?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 24, 2010 | Kodak C1013 Digital Camera
Kodak z1085 is telling me my memory card is protected. How do I fix it so I can use it?
Nov 24, 2010 | Kodak EASYSHARE Z1085 IS Digital Camera
Whenever I tried to make s shot it says "protected
Nov 22, 2010 | Sanyo Xacti VPC-T700 Digital Camera
My Camera Wont Let Me Take Pictures It Says Card Protected What Can I Do?
Nov 21, 2010 | Polaroid i835 Digital Camera
What does "memory card is write protected" mean and how can I fix it? THANKS
There are several possible causes for "memory card locked / write protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Sep 26, 2010 | Nikon Coolpix L14 Digital Camera
How do I erase my memory card? Thanks, Chris
You can format your memory card using the camera's menu to "format" removes all files and reinstalls the cameras' directory to the memory card for use in the camera.
Note:- Formatting the memory card erase all the data including protected images and other file types. So, once you formatted the memory card there is no way to restore them.
Rating the solution is highly appreciated...Good Luck
Mar 03, 2010 | Nikon Coolpix 4600 Digital Camera
Memory card write protected
Check the side of the memory card. Some of them have a little switch that turns on/off write protection. If there is no switch, you can try to format it in the computer first, then put it in the camera and format it again.
Jul 11, 2009 | Nikon COOLPIX S51 Digital Camera
Olympus FE-230 Digital Camera Logo
65 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
