Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
CAN A SPLIT SYSTEM BE ALTERED TO BRING IN FRESH AIR
  • 81 Answers
No sorry the air is circulated from the room and sucked in front the top of the unit. the only way to get fresh air around is to open up windows then put the unit on fan only.
Posted on Nov 10, 2010
I drive a vw polo tdi 2006,when I went up the brigde it made a strange noise then black smoke started coming from the exhaust could not see even the car behind me,what coused it?
TDI I take is turbo direct injection so if that is the case you have a turbo problem or a split intercooler
what ever , the air/ fuel ratio has altered to excessive fuel
the noise could be a blown intercooler hose , split intercooler or turbine wheel in the turbo breaking off
Take it in for a proper diagnosis and have the codes read
Sep 18, 2016 | Cars & Trucks
Error c5
C05 error indicates no communication between indoor and outdoor units and remote control. Replace the remote batteries with fresh duracells first. If that doesn't fix the problem, verify the indoor and outdoor unit are wired together properly. If still no love, a tech will need to come visit. CALL SANYO TO SCHEDULE A TECH IF NEEDED. Mini-split units are new to the industry, and not all HVAC techs are good at fixing them.
Mar 30, 2014 | Sanyo Split System Air Conditioner
Installed 18000 btu split system heat pump and condensing unit is freezing up in cold weather 15 degrees out side air.
Actuall, out door fan sucks fresh air to cool the condensor when it's on "Cool" mode. If it is in " Heat mode' if the fan should run only on pressure build up. May be pressure switch is faulty.
Melt the ice with Torch gun, and check again.
Dec 15, 2010 | LG Heating & Cooling
Just wanted to find out if the vent should be open or closed when air conditioner is on..
If you are talking about a whole house ducted system, it is best to keep all vents open.
If you are talking about a window air conditioner, the vent is mainly intended to bring in fresh air, usually people keep them closed, unless you are just running the fan only and want to bring in cooler fresh air, like in the early mornings.
If this has helped, please rate me, or contact me back with any further questions that I can help you with.
Sincerely,
Paul Gibson
May 03, 2010 | Heating & Cooling
Temperature from window vent is hot when air con on othersd are cold as set
It's likely that your car has whats called a "Blow through system". The system has a few vents that aren't connected to the a/c or heatin system and just bring in straight air from the outside. The point being that fresh air is always circulated. Are the same vents cold in the winter even with the heat on?
Nov 20, 2009 | 1997 BMW 5 Series
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
NEC split A/C is not cooling for me
if your outside and inide units are running and your tstat has fresh batteries and your air filter is fresh then I will need more info to help solve
Jan 05, 2009 | Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
42 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
