Question about Haier Energy Star ESA3183 Air Conditioner
My HWF05XC5 is not cooling my room
Sounds as if it going to work but then it resets and only regular air comes out , i sort of reset the power wait three minutes and try again for the same results
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Call 1-877-337-3639 or haier units, then the next page haier unit and model #'s.
Posted on Sep 07, 2008
My thomastate for ac is showing a flashing snowflake and will not make the ac work how to reset it
The snow flake indicates that the mode is set for cooling, not hearing our both heating and cooling.
There should be two temperatures given by the thermostat, one is the actual room temperature and the other is the temperature setting. The room temperature reading only changes with room temperature change. The thermostat setting temperature changes when the up or down button is pressed.
If your room temperature, say it it's 80° and the temperature is set lower than 80° with a snowflake, the fan should run and start blowing cool/cold air. If you system does not do this, then there is a problem. The problem can be the fan housing cover is not making contact due to the cover not installed properly, nothing will run in this case, no fan. It can be there is no power delivered to the indoor fan, or to the outdoor fan, both these fans must run during thermostat calling for cooling.
The thermostat is not something to be reset as you asked but rather, you check that both fans run and that the outdoor fan makes compressor noise.
Come back with your findings or call a service person. One last try is to shut power to both indoor and outdoor parts of the system and then restore power in attempts to reset the unit or power circuit breakers
Oct 01, 2017 | Heating & Cooling
Unit will not blow cold air after starting up for first time this season
That's because this unit is only designed to cool a room to approximately 75 degrees. http://www.fixya.com/support/p114531-delonghi_pinguino_pac_700t_air/manual-1811/page-2 It's not supposed to make the room cold, just comfortably cool. It automatically switches off of Cooling when it achieves this. If you want it cooler, you'll have to get a traditional air conditioner unit (like a window unit).
Sep 01, 2007 | DeLonghi Pinguino PAC-700T Air Conditioner
A Trane 20 Ton roof mount A/C unit model # YCD241B4L0DD does not work... Test sequence works OK through it's steps but after power off reset jumpering TB1 to call for max cooling 1+2 does not...
Hi
Please check the bellow link to diagnose what could be wrong with your AC…
http://www.inspectapedia.com/aircond/aircond1123.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 24, 2010 | Heating & Cooling
230/208 Volt Built-In Room Air Heat/Cool Unit blows cold air, not heat. Unsure if it may be thermostat, if so.. where is it? Another one blew fuse. Where is it located?
To locate the fuse;
1. Turn the power off or unplug the Room Air Heat/Cool unit.
2.Follow the power cord of the unit. This will normally
terminate at the fuse terminal/power reset button., where you can replace the fuse.
3. After the fuse/power reset button terminal the wire
go to a thermostat normally located at the air output
section at the front portion before it goes to the motor
and heating element, while the other wire may connect direct from the fuse terminal to the motor or
heating element.
This is just the basic electrical set up, it can be modi-
fied. Hope this will guide you in locating the fuse and
the thermostat.
fied
Jan 06, 2010 | GE Built-In Room Air Heat Cool Air...
The compressor works it just kicks out after two hours
the way to verify if the thermostat switch is the culprit : is to shut off the power, "jumper" the thermostat> the device at the other end of the bulb you described, and see if it freezes you out... if the compressor kicks off while this switch is jumpered the compressor is the culprit.
Jul 12, 2009 | Haier HWF05XC5 Air Conditioner
My air conditioner has power but only the fan works no cool air is coming out is it broken, or can I fix it?
sound like the compressor is not turning on if this is Wall unite they are worth investing money into buy anther one.
Jul 07, 2009 | Haier HWF05XC5 Air Conditioner
I just put mine in the window and it won't start. Not sure of the model...two years old, has three settings. The power light is coming on, but it just won't work. I've tried multiple outlets. I did store...
Sometimes at the end of the chord where the plugin is there will be a reset switch push it in and it should restart. You might have a circuit board problem would be the next thing. If the power light comes on and the unit doesn't. I hope that was helpful to you Thank You For Using Fixya.Com
Jun 18, 2009 | Haier HWF05XC5 Air Conditioner
Problem in the power Plug AC doesnt turn on
That means you have a short to ground somewhere in the system. They can be a pain to track down. You must have a volt/ohm meter and check each component and part individually untill you find the short.
There is a small chance that the GFCI is bad itself.(The part thats poping off and has the reset button.)
Dec 28, 2008 | Haier HWF05XC5 Air Conditioner
Will not start
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3632 Hope that helps! ;)
Jul 27, 2006 | Haier HWF05XC5 Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
74 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
