THERE IS PAPER JAM IN FUSER FIXING ASSEMBLY. WHAT CAN I DO FOR SOLVE THE PROBLEM
  • 4,338 Answers
The fuser is bad and needs to be replaced. What model is it?
Posted on Nov 10, 2010
Paper jam in fixing assembly
Open the fixing unit and open the fixing unit film open it and greasing it with white grease and fuser oil after it problem will be solve..
Apr 20, 2015 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Canon ir 3300 have a problem for paper jam in fixing film so how to solve the problem
there is an error in the rotation of the fixing film.
check the fixing film sensor and make sure that all the wiring and the connectors are connected securely.
if it persists, consider replacing the fuser fixing film
thanks
Aug 17, 2014 | Canon IR 3300 Digital Copier
Fix inner paper jam hp cm1312
I Suggest You To Watch HP Video Gallery Fixing Paper Jam HP Deskjet 1510 All in One Printer To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support Team.
Nov 19, 2013 | HEWLETT-PACKARD HP Color LJ CM1312 MFP...
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
Solution to solve system Error E007 on IR 2016i copy machine
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place.
fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon CLC 1140 Copier
Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
May 09, 2008 | Canon imageRUNNER 5570 Copier
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
64 people viewed this question
jasbo
jasbo
