Question about Metrologic Instruments Voyager MS9520 Handheld
My MS920 scanners beep but there's no display on the screen. Tried getting a USB converter, this only beeps upon connection and completely stops. Sidney
2 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: StratosE ms2122, it scans it beeps but nothing appears.
most barcode systems will scan and beep when presented with a valid barcode (if the barcode conforms with a valid format). This just means it is powered up (it does not require any input from the computer to do this) I believe you have a driver issue, which controls how the scanner communicates with your computer. please check that you have up to date drivers and software from the manufacturer's website and that you can find the device listed (by name) in your Device listing Gareth
Posted on Jul 26, 2007
I have a Acer Verton E430 Desktop. Suddenly upon restart after the initial beep and Acer splash screen returns to restart with one short beep and process continues on and on.. Advise how to solve.
One short beep can be DRAM refresh failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Dec 02, 2014 | Acer Computers & Internet
My Dell Poweredge 1550 won't connect to the screen. It also constantly beeps upon startup
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.
Thanks,
--Brian
Nov 02, 2013 | Dell PowerEdge Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
PS3 will not switch to HDMI cable. 1) Tried holding power button. Will not beep 3 times. Just shuts off. 2) Tried using both cables and changing display settings to hdmi.
try holding poew buton again let it beep 3 times
then hold it a second time and it would beep once solid beep and then listen for two short beeps then release the power button you will see a screen marked connect controller with usb and press ps button to continue you are now in service mode then just restore default settings and you should be up in hdmi
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
One long beep and 2 short beeps
Depending upon your BIOS manufacturer, generally this POST error code means either a video card problem or a motherboard problem. If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Jun 27, 2009 | HP Pavilion zd7020US Notebook
Screen won't appear upon start up and I get 3 beeps but no screen
what you are hearing is a beep code, if its 3 short beeps then its the memory which has developed a fault and it may need to be replaced
Nov 16, 2008 | Acer Aspire 5100 Notebook
ASUS A832-SLI Deluxe Display Errors
neckbeard
remove the memory and gently clean it very well and then connect it back to motherboard. if got long beep then memory damage.(replace memory) if got tree short beeps, clean the video card and connect it after cleaning if got same beeps ( then replace video card) thats only only things. Good luck.
Dec 16, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Actually HHP IT4410 LR
Have you tried reinstalling the drivers? Or downloading the latest driver from the manufacturers website? My father had the same problem with his scanner, and all he did was reinstalling the drivers and it worked fine afterwards.
Apr 10, 2007 | HHP IT4410HD
Metrologic Instruments Voyager MS9520 Handheld Logo
59 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
