Question about Dishwashers
Kenmore elite dishwasher doesn't cycle repair man says circuit board needs replacing. clean light blinks 7 times
  • wisaac Jun 17, 2008
    model 66517262401 ser no. FS1801463 purchased June/2005
  • wisaac Jun 22, 2008
    clean light blinks 7 times. this is an error code. what does it mean?
    Master:
  • 638 Answers
What does it mean you can get here
http://video.aol.com/video-detail/clean-light-blinks-7-times/346645204
but to get repaired you have to call the tech.
or
The solution required disassembling the door to get to the control panel electronic board. You'll notice a flat transparent cable coming out of one end, twisting under the board and going into the door panel. In the middle of the door, there's a number of wires taped together that curled over the flat cable. Look for any black tape residue on the flat cable, which seemed to be causing a short circuit and confusing the electronics. After carefully removing the tape residue from the flat cable, the problem went away.
Hope this helps :)
or
key pad need to be change
or
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
or
You can also pres "normal wash" and "heated dry" buttons back and forth and it will reset the dishwasher and work normal again
or
reset the dishwasher and again start it up. turn on the hot water, make my selection for cleaning, the dishwasher starts and runs like normal.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 22, 2008
  • 6,487 Answers
A clean indicator that flashes/blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's eletronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
Once corrected, the error display may have to be cleared from the control manually. That can usually be done by putting the unit into diagnostic mode by pressing the key sequence 'Heated Dry, Normal, Heated Dry, Normal' and then pressing cancel.
Hope that helps.......
    Genius:
  • 3,422 Answers
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again,
Please don't forget to rate or accept the solution
    Sergeant:
  • 243 Answers
Yes leethedeuce is right here. Dont bother with Eskes Copy solution of another expert. LeetheDeuce posted the correct information for you to be able to fix your problem.
thanks,
Nathan
Posted on Jun 17, 2008
  • Dishwashers Master
  • 13,433 Answers
Please watch this video
Most likely you will have to replace it.
  • 4,472 Answers
Http://video.aol.com/video-detail/clean-light-blinks-7-times/346645204
Go here and do all this and then you will know.
Thanks,
Lee
  • 4 more comments
  • Lee A.
    Lee A. Jun 17, 2008
    Check heater element. Should be between 10 and 35 ohms of resistance
  • Lee A.
    Lee A. Jun 17, 2008
    Thanks eske you posted the exact same thing as me.
  • Lee A.
    Lee A. Jun 17, 2008
    Also they have come out with a 2nd generation control board to help some of these problems.
  • Lee A.
    Lee A. Jun 17, 2008
    It has a new heater relay on it this is most likely why you need the replacement.
    Hope this was helpful for you and if you would be so kind as to rate me accordingly. It is greatly appreciated.
    If you need any further assistance please let me know,
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    I still look forwarding to hearing from you. If all worked out well I would hope you would accept my solution and rate accordingly.
    I am here on a daily basis to assist and you can always use the Ask me feature.
    Thank you,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    Still hoping to hear from you to know how it went.
    Thanks,
    Lee
    Master:
  • 497 Answers
May i know the model no pls
  • Yaz  S
    Yaz S Jun 17, 2008
    i highly recommend you call for service..
    'tc
    President:
  • 2,712 Answers
Check this article for some possible steps:
http://www.repairclinic.com/0088_9_1.asp
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Kenmore 665 - clean light blinks 7X - help
Get its circuit kit checked, it is malfunctioning.
Custom Parts For Mercedes
Aug 08, 2012 | Kenmore Dishwashers
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Does not go thru dry cycle, clean light blinks 7 times
clean light blinking is a tricky problem to find and cure can be a few different issues.heres an edited down version of official manufacture explaination,its been an issue (I would call manu for assisstance in repairing this further)
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down dish washer. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The Proper incoming water temperature should be between 120°- 140° F.
Possible causes of insufficient temperature rise would include wires off at thecontrol, heating element, thermistor,inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Feb 27, 2008 | Kenmore 24 in. 16034 Built-in Dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
230 people viewed this question
Top Dishwashers Experts
