Question about Sanyo VPC-CG65 Camcorder
AV jack The AV Jack is not working with headphones or the supplied AV cable.
    Genius:
  • Sanyo Master
  • 1,689 Answers
The jack itself may be defective, there may be a cold solder connection on the circuit board, or the driver circuit to the jack is defective. The unit will have to be serviced to fix the fault.
Jerry G.
Posted on Jun 17, 2008
I have a Denon avr 391 and it worked fine for 4 years. Now I cannot get any sound out of it. Any idea what's going on. Help
could be a bad headphone jack. There was a commong problem with denon receivers around that time where the headphone jack had contacts that would short and make the unit act like there were headphone plugged in even when there wasn't. Sometimes you can clear the error by inserting a headphone plug and unplugging it a couple times. If it continues to happen, then you can get the headphone jack replaced.
Jan 04, 2015 | Denon Avr-391 Av Home Theater Receiver
Same problem as below, I have the Denon AVR 790 and the sound keeps switching to headphones. Blowing into the socket did not help. Both unpluging the AV and putting the headphones in and out fix's the...
The unit thinks there are headphone plugged in even when there are not. You need to have the headphone jack replaced. This is a common problem with this model. Another way to fix it if you don't plan on using the headphone jack is to unplug the cable going to the headphone jack board. This will disable the headphone jack, and stop it from sending an erroneous signal to the micro.
Jan 31, 2014 | Denon Avr-790 - 7.1 Channel Home Theatre...
Connect sony headphones to sanyo television
If the tv does not have A head phone jack on it, No type of head phones will woprk on it.
Aug 30, 2012 | Sony Audio Players & Recorders
I have a Digital Audio/Video Control Center, model number STR-DE695. There is a AUX button on the front, but I can't find the aux cord to plug my iPod to my system. Help!
Check the back and front of your system. The AUX input may be either:
- two red and yellow holes (known as phono L R)
or
-a 'headphone' jack input hole
the cable might not have been supplied with the system. Also, the cable you need may not connect to your iPod through the large connection, it may actually connect through the headphone jack.
So, you may need either:
-a cable with a headphone jack on both ends (one for the system and one for the ipod)
or
-a cable with phono L R on one end (for the system) and headphone jack on the other end(for the ipood)
Aug 27, 2011 | Audio Players & Recorders
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
What cord do you need to plug the ipod into the karaoke machine
This depends on the karaoke machine in question. Mostly the Ipod accepts a 3mm earphone jack and the karaoke is supposed to support the regular av in 2 pin jack. so all you need to do is get the single 3mm headphone jack to 2 pin av in jack. that should work perfectly.
Hope this solution has been helpful?
Dec 29, 2010 | GPX Karaoke Party Machine
How do I play my iPod touch through my 55" Samsumg led 3d series 8 tv?
You need a cable, either a headphone jack to red/white (audio), or a special headphone jack with yellow (video) and red/white (audio). They look like this: Apple Component AV Cable
Oct 03, 2010 | Samsung Televison & Video
My headphones don't work, but the wires are not broken. only one side works if you put pressure on the jack.
What you describe means that there is a connection problem at the jack end. e don't if it's at the male jack (the one at the cable) or at the female one (the jack on the device). Check your headphones at another device to clarify this. If the problem is active on the other device too, you have to fix the male jack. In order to do this, you can easily change this end with another jack (complete jack and part of the cable from another headphones) by connecting the cables. The best solution is to change the jack with another one and solder the cables but since these cables are very thin, it isn't so easy.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 02, 2010 | Skull Candy SCSBP35 Consumer Headphones
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Aug 06, 2009 | Sony MDR-V700DJ Professional Headphones
Sanyo VPC-CG65 Camcorder Logo
76 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
