Question about Intel Motherboard
Identify older Suttle motherboard
I have an old Motherboard with AMD processor. It is supposed to be a Shuttle brand. I would like to find the model number and a manual for this motherboard.
Bios not save
Posted on Oct 11, 2012
    President:
  • Intel Master
  • 1,314 Answers
If you look on the motherboard, there should be some sort of nomenclature printed on the motherboard identifying the model of it. You can also try to use a utility called everest which may identify the motherboard without you actually opening your case. You may download a trial version here.
Posted on Jun 17, 2008
1 beep then shuts off
Hmmm, one beep is good! lol!
Means P.O.S.T. is good.
http://www.newegg.com/product/product.aspx?Item=N82E16813186029
I see we're working with an AMD processor, and a Socket 462 (Socket A), motherboard.
Let's look at some basic installation problems for that motherboard, and see if any fit;
1) Since it is an AMD processor motherboard, you have to be SURE that Thermal Paste has been applied PROPERLY, and applied.
http://www.hardwaresecrets.com/article/274
An AMD processor runs hot, for the models that fit that motherboard.
If no Thermal Paste has been applied, the AMD processor could have burned up.
2) Anti-Static Precautions:
I know, I know. But you would be surprised with those of us, who do not know what Anti-Static Precautions are; and work on computers.
(Hmmm, wonder why it doesn't work? Must be a bad motherboard)
3) Mounting to the Support Plate.
The Support Plate can be a separate metal plate; or is part of the computer case.
Mounting of the motherboard to Support Plate can be done with plastic Spacers; or metal Standoff's.
(Standoff. Shapes vary a little, but basically; 3/8ths to 1/2 inch long, hex shaped, threaded shaft on one end; and a threaded hole on the other end)
If a Standoff is NOT mounted to a motherboard mounting hole; and is just sitting out there on the Support Plate; it can touch exposed solder joints on the bottom of the motherboard, and cause a Short Circuit.
MOST of the time if the 'offending' Standoff is removed; or placed where it should be, (Motherboard mounting hole), then the motherboard, etc may be OK.
4) Power Supply:
If the Power Supply was on it's last leg, this may be the 'straw that broke the camel's back'. Power Supply went to the Power Supply graveyard in the sky.
If the Power Supply does not have enough power (Wattage, and Amp's), then you would also see the problem you stated.
New Power Supply, or old? What is the manufacturer, and model number?
Post back in a Comment.
What AMD Socket 462 (Socket A) processor did you install?
What Ram Memory?
How many optical drives? (CD/DVD drive)
How many fans?
Regards,
joecoolvette
Dec 27, 2012 | Foxconn K7S741GXMG-6L S.462 Motherboard
I am not able to get AMD Sempron (tm) processor LE-1200 audio driver.....can u slove my problem..
Audio driver? For your processor? If anything has an integrated audio chip, then it's your motherboard. AMD has just come up with a technology that includes a graphics chip in their processors, but I've never heard that anyone got a sound chip there. So, check your motherboard model, then check the manufacturer's site for drivers, they must be there, available for free download!
Sep 05, 2011 | AMD Sempron LE-1200 Processor (2.1GHz)...
Like to replace my processor which is AMD Duron 900MHz to Motherboard Gigabyte 7VM333M-RZ. Which current processors are compatible with this board? Please advise. I want a current fast processor.
Hi, As far as I can see, this motherboard is very old, and the faster processor you could get would be around 1.8 ghz, single core. Here's the list of supported processors:
http://www.cpu-upgrade.com/mb-Gigabyte/7VM333M-RZ.html
What I would suggest is that you buy a motherboard/cpu combo, then you could get a quad core with a recent motherboard for less than 150-200$. Of course you'd have to be willing to change your motherboard, but unfortunately, you're not gonna get a good processor with your current motherboard, and computer parts (like Ram, hard drives, video cards) are going to cost more and more for their rarety, while they are less performant.
Best of luck to you!
Mar 14, 2011 | Computers & Internet
I want graphic drivers for AMD Athlon XP 1700+ running windows XP professional SP2..... please help me.
There is not enought information to suggest which motherboard you have. Take a look at your motherboard for the board identifier. You can also go to belarc.com and download a free board analyser. This program will give you the actual idenfier for the motherboard as well as other useful information for your hardware and software.
Once you identify the motherboard, go to
http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.7
to get the drivers.
Aug 08, 2010 | AMD Athlon XP 1700+, 1.47 GHz (AXP1700BOX)...
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
What is the best processor for ASUS A7A266 Motherboard
This is a really old board.It's a socket A but it's older than the athlon xp series. You're stuck with an amd athlon not the xp series. Good luck finding acpu for that. Try ebay.
Jul 11, 2009 | ASUS ALi Chipset A7A266 (A7A226)...
Windows xp sp2, amd sempron 2800
you just need to go to the website of your motherboard brand, then after that you just click the motherboard, when you are now in the site just type your motherboard model, then click the driver, then chose the US when you download the sound and video driver
Jun 30, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Asus K8U-X motherboard,which ram memory , and processor support?
hi..for this mother board model asus K8U-X only same brand Processor u can oly use.Like if u use Sempron made by AMD only AMD Processor for that board.Memory support is DDR1 PC400 1gig up to 2gig...good luck and Have a Nice Day..
Jun 14, 2009 | ASUS K8U-X Motherboard
List Motherboards that Supports Intel Prescott Processors
25455, 25456, 25457 ASUS Terminator 2 (T2-P) Yes All - - 25458 ASUS Terminator 2 (T2-R) Yes All - - 28389 ASUS Pundit-R Barebone Yes All All - 28073 MSI MBOX 661FM Yes All All - 27438 Shuttle SB75G2V2 Yes All FB75S017 up to 2.80E 25257 Shuttle ST61G4 Yes All FT61S01Z up to 2.80E 26962 Shuttle ST62K Yes All FT62S00N up tp 2.80E 27280 SuperMicro 5013C-M Yes All All - 27283 SuperMicro 5013C-M8 Yes All All - 27363 SuperMicro 5033C-T Yes All All -
Jan 17, 2009 | Gigabyte GA-8SQ800 Motherboard
Upgrade processor on ALI 1541 motherboard
May need to be configured in the Bios, but also some older boards had processor adjustments on the motherboard, either with a block of little white dip switches, or with jumpers that you remove or replace depending on the processor. Some times the settings for the processor are printed on the board too. Are you sure the motherboard can take a processor up to 500MHz.
If you don't have the manual for the motherboard have a look on it for the make and model number and search google for it. If it is available it will probably be an Adobe pdf file so make sure you have Adobe's Acrobat reader.
Mar 12, 2008 | Computers & Internet
Intel Motherboard Logo
123 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
